INT: Red Door Lights
    This is for the lights on the doors
    Whats needed?
    -Flat head screw driver
    -Transparent Red paint- I used krylon stained glass
    -Rubbing Alcohol
    -Rag
    -2000 grit sand paper
    1. First pop off the the covers from the door with the flat head screw driver
    2. Sand them down with 2000 grit paper
    3. Clean them real well with alcohol
    4. Shoot the paint like 2-3 light coats( I prefered to go darker)(inside or outside)
    5. Clear them(optional)
    6. Let them dry
    7. Pop them back in and your done
    Final Results:
    '04 SB AP2 211whp 150wtq
    not bad. it looks like the UK version. and you could always just sand the paint off if you get sick of them. later.
    Avoiding dirt at all costs
      yea when i saw them in your other thread i thought u bought them off UK.....nice indeed.
        Thanks man, I got the idea of painting them after I saw his lights
          Wouldn't it look better if you just put the paint on the inside of the cover? It looks good now but if you put the paint on the inside wouldn't the outside be more shiney and make it look better?
            You can just spray clear on it to get it shiny
              Nice DIY. A long time ago I couldn't find colored bulbs that would fit so I used translucent paint and went over the clear portion of the bulbs. It didn't turn out as blue as I wanted them. I tried red and it came out pink. Nice DIY
              Oh and Dayum thats a cleanass engine bay! Looks so clean you can eat off it!
              I need a custom turbo manifold built....
              707 NorCal NinjaZ
              Honda Twincam Motorwerkz?
              "I am the Yakuza CB7!"
              '92 Accord Sedan SiR
                Nice diy, i like the way they came out i myself went and bought the other set from UK Accord
                  And I bought the first set, but this is a nice DIY
                    Lucky that you bought the first set, cause he told me that they were pretty hard to come by, and lucky me for getting the 2nd one
                      I dont mean to hijack ya thread but was just gonna show the light output of the standard OEM RED EDM lights as to the DIY ones
                      DIY Door Lights ^^^ Originally Clear Tinted RED
                      EDM Door Lights ^^^ Come RED as standard
                        I really like that...looks nice and clean. I made my courtesy door lights blue by chuckin leds on the clips...was easier i thought...but i guess paint will last longer.
                        my kitted cb7
                        Soarer Source | The Home Of The Toyota Soarer and Lexus Sc300 sc400
                          i also thought about doing that but i did'nt know if it would come out right.
                            I did this and it looks really nice at night.
                              Nice DIY. I would like to do just the opposite, from red to clear . My door lights are OEM red.
