If you mess something up, you or the car, while doing this, its your fault, not mine. Enjoy!!
Reason for doing this mod:
Swapping in a different year center console 92-93 into 90-91 etc
90-91 ebrake is centered, 92-93 is offset towards passenger side
Tools needed:
Philips screw driver
10mm wrench, sockets and ratchet
Electric drill
5/16" bit
Large flat washer
1. Remove the center console using the screw driver
2. Un-bolt the e-brake from the floor. It's held in with two 10mm bolts.
3. Get the drill out and drill the new holes. I recomend you put the center console in, line the e-brake handle up, hold it there and remove center console, mark where the holes need to go.
4. The hole on the drivers side is real close to the edge of the bracket. Here is where the washer will be used
5. Bolt it back into place using the new holes. Using the 5/16" bit will give you a little leeway to move it, use that to line it up perfectly.
^Passenger side
^Passenger side
^Drivers side with large washer
^When its all done it should look like this
L8r all
Tools needed:
Electric drill
5/16" bit
Large flat washer
^Passenger side
^Passenger side
L8r all
