INT: Misaligned glove box/Light stays on
    Interior - Glove Box Door Misaligned, Light Stays ON
    Notes
    Bulletin No.
    92-034
    Issue Date
    SEP 25, 1992
    Model
    1990-92 ACCORD
    Applicable To
    ALL
    File Under
    BODY
    Glove Box Light Stays On or Glove Box Misaligned
    PROBLEM
    The glove box light stays on when the glove box is closed, and/or the gap between the glove box door and the dash is not even.
    CORRECTIVE ACTION
    Install the part listed under PARTS INFORMATION, and/or adjust the glove box flush with the dash.
    1. Using a sharp utility knife, cut the tube cap (see PARTS INFORMATION) to measure 12 mm.
    2. Press the tube cap over the glove box switch plunger.
    Glove Box Not Square With Dash1. Open the glovebox and grasp the top right and left corners.
    2. Push up on one side of the glove box and pull down on the other (depending on which side is high or low), to make the glove box square with the dash.
    NOTE:
    After making this adjustment, it may be necessary to adjust the side-to-side clearance.
    Glove Box Uneven Side-to-side
    1. Open the glovebox and grasp the side with the least amount ot clearance.
    2. Push or pull the glovebox toward the side with the largest amount of clearance to center it.
    3. Close the glovebox and check the side-to-side clearance and squareness with the dash.
    NOTE:
    There should be approximately 2 mm (0.080 in) clearance on either side of the glove box.
    Top of Glove Box Uneven With Dash
    1. Open the glovebox just enough to grasp either the top or bottom edge.
    2. If the top of the glove box is too close to the dash, grasp the top of the glove box and push straight down slightly.
    3. If the top of the glove box is too far from the dash, grasp the bottom of the glove box door and pull up slightly.
    4. Close the glove box and check for a 2 mm (0.080 in) gap between the top of the glove box and the dash.
    5. If necessary repeat steps 1 through 4.
    Glove Box Not Flush With Dash
    1. Check the glove box for squareness and side-to-side clearance first. Adjust if necessary.
    2. Open the glove box and check to see if the striker is centered with the latch assembly opening.
    3. If necessary, center the striker by tapping on the side of the striker with a rubber mallet. Adjust the striker until it's centered with the latch assembly.
    4. Close the glovebox and check for free play at the latch. If there is free play, open the glove box and bend the striker up or down as necessary to eliminate the free play.
    5. Close the glove box and recheck all adjustments.
    PARTS INFORMATION
    Glove Box Tube Cap P/N: 77502-SM4-999
    H/C: 415 5644
    SuddenCb7 - 1992 Honda Accord EX Coupe
    On this issue, it may not always be JUST a misalignment problem. It was on my first CB7 and on my current one when I bought it but I put a new black dash in and the framework broke causing the same problem after a year or so. If this DIY fixes it, good on you. If not then you've got more serious problems.
      Another great find, my glove box light stays on all the time.
        hahahaha i forgot there was a glove box light.
        Dr. Jekyll by day Mr. Hyde by night
        02 Pontiac Firebird W68
        92 Dodge Stealth RT/TT
          i've never seen a cb7 that didn't have a sagging glove box. later.
          Avoiding dirt at all costs
            wtf, theres a light in there? lol, mine doesnt have 1. LOL. but yeah, mines closes but not flush
            1993 Honda Accord LX
            2006 Yamaha R6
            2004 Acura TSX
              I thought the light was just on at night when you cut on your lights, did not know it was a switch to cut the light off. LOL
              My CB For Sale
                x2..but o well..i can live with it
                -1992 Accord EX H22 234whp 185wtq
                -1993 Accord EX SOLD
                -1995 Accord EX Wagon Daily Driver
                -2012 GMC Canyon V8 4x4
                  my glove box works fine
                  My Members Ride Page
                    Good find. Ahh the rewards of a successful search. I will be doing this one tomorrow. Tired of seeing my glove box light come on everytime I get on the gas. Later
                      same here
                      93 Accord SE no tranny:Parting out
                      http://www.cb7tuner.com/vbb/showthre...52#post2070752
                      86 Ford Ranger fuel problem
                      Explorer Fund:$1595.23
                        this is perfect!
                        ive had this problem ever since i got the car and ive been looking for the solution
                        thanks
                        MY CB7
                        FULL part out thread:
                        http://www.cb7tuner.com/vbb/showthread.php?t=204494
                          wowww....there was a bulletin on this?? Thought it was just my car, just about everyone who rode shot gun had to point it out......never bothered me but its something to do
                          1992 Accord Wagon (RETIRED)
                            ^^^Im taking it you searched this problem out?
                            Wow...a newb searched and found a thread. Nice.
                            Yeah, this is one of those problems that 95% of us have. Just like the crappy heater knobs, window clips and rear qtr rust.
                            KeepinItClean | EnviousFilms | NoBigDeal | YET2BSCENE | . ` ' / . | click here.
                            Originally posted by Jarrett
                              Yup. Everytime someone new sits shotgun... "Hey, you're glovebox light is on."
                              "Yea, I know."
