INT: Front Seats Removal
Difficulty:
Easy
Time:
5-15 minutes
Tools:
Wrench/Socket wrench - 9/16" or I think 14mm
Flat head screwdriver - small tip
Instructions: Refer to the pictures below for visuals.
1) There are plastic clips hiding the bolts, so you'll need to carefully pry them off using a flathead screwdriver and your fingers.
2) There are 4 bolts (2 front, 2 back) for each seat. I used a 9/16" wrench to remove the bolts.
3) The front driver's side seat has a wire on the bottom of the seat that you need to unplug from the corresponding floor adapter before removing the seat from the car.
It's just about as self explanatory as it can get.
Front passenger side
Difficulty:
Easy
Time:
5-15 minutes
Tools:
