Originally posted by starchland
SUSP : Suspension Install
according to http://www.honda.co.uk/owner/AccordManual/400/12-38.pdf when removing the rear spring/shock assembly, the upper ball joint has to be disconnected is this necessary?
Leave a comment:
Originally posted by lowoctane
you can do what i did, see how far we could launch the shocks when we where unbolting them while they where on the ground, wow those things are powerful, they could put on a hurtin if they hit someone lol...even though it blew my stock ones in the process.
Leave a comment:
anyone have a list of the torque specs for reinstalling the bolts?
Leave a comment:
Originally posted by accordztechif u were changing struts on a lowerd car do you need to compress the spring again? or can u just undo the bolt?
i heard u can also just undo the bolt when the car is on the ground, and then lift the car up and the spring will be decompressed as well...?
i wouldnt really trust the doing it while on ground bit, do that at your own risk.
Originally posted by WiKKeDV16yeah.. haha.. then how do u get the spring out if its uncompressed??.. lol no way in hell ull get it out..
Leave a comment:
Leave a comment:
Leave a comment:
Originally posted by i_love_cb7how long does it take to do this and how hard is it?
and don't u need a spring compressor??
Leave a comment:
Leave a comment:
Originally posted by accordztechi have a tip:
i had an issue the other day that i think you guys should hear. when putting back the fork on the strut there is this alignment thing that will only go on one way, or you cant get the stupid bolt on...i didnt know this and it never ligned up correctly...i had to take everything apart again.
Leave a comment:
i have a tip:
but i like these directions. my steps were:
unbolt lower control arm bolt
unbolt brake lines
unbolt the fork and pull down to allow the strut to be free
unbolt the strut mount and take out the strut
pretty damn easy. took me like 20 minutes.
oh i found a shop that sells coil compressors for like 10 bucks! hella happy! i bought a set.
Leave a comment:
I'm going to be swapping out my AGX's for Konis soon so I can take pics as I do it. Anybody have certain pics they want?
Leave a comment:
Leave a comment:
