SUSP: Rear cross member swap / Rear sway bar install
    i been meaning to ask you the purpose of this???? I understand the wagon amrs are different, and so is the cross member, but what's the purpose???? do you feel a difference??? besides from the weight that you added...
    JDM Parts for sale
      Well he and I did this to my car, so as for the feeling a difference part. YES! haha I have a DX so my control arms were different and we put the cross member on so I could put a sway bar on. On the original DX cross member there is no place to mount the sway bar. So I mean I don't really know how much the control arms made a difference but I know the cross member was worth it cause the rear sway bar made a HUGE difference!
      Click For MRT
        Originally posted by C-Rod View Post
        ^^^^^ so this is pretty much the same DIY...only better, explained and more pics....
        gotcha.
        JDM Parts for sale
          Haha Yeah its the exact DIY, I found it after Tippey posted this and I thought that the other DIY did a little bit of a better job
          Click For MRT
            i say skip the trouble
            i swapped memebers, because i got it for free, tried a 16mm sway
            and compared to not having one, it is a difference, but a 22mm from suspension tekniques is the way to go, shitty part is, after you busted ass swaping crossmembers, the ST bar bolts up using the long 17mm bolts
            understeer is non-existent in my car anymore
            also i suggest swapping the front with a 26mm from a cd5 ex
            Just do what PR CB7 said.
              Great DIY
              Thanks for the tip, tippey
              Form.Follows.Function
                Does the 1993 LX coupe have the same crossmember as the EX? I'm wondering if the control arms and crossmember have the provisions for a rear sway bar?
                Thanks
                1993 Accord LX Coupe 5spd
                  Sway Bars/Anti-roll bars
                  DX/LX = No
                  EX/SE = Yes
                  If you want to install an OEM sway bar from an EX into your LX you will need the rear sway bar AND the rear crossmember from the EX. DX and LX models did not have the mounting points for a sway bar at all.
                  The good news is that stuff is dirt cheap or in my case...free. just look around and see what you can find. Shouldn't be too hard to get what you need and will be well worth it. Understeer will be dramatically reduced. Good luck!
                    Just to add on what function>form said
                    The LX wagons actually have rear sway bars
                    Although the 1993 10th anniversary edition has rear disc brakes it does not share the nitrogen charged struts and sway bars from the EX models.
                      i did this as well except with a 94 EX rear end just wanted to let you guys know the 5th gen rear end with struts and all completely bolts in. disk brakes are fantastic too! i already had an ex rear end except i have a 91 so it had drums and 330ish thousand mile worn out bushings. also i have heard the 5th gen sway bar is larger and it may be easier to come by
                      Blake.
                      1994 Accord Part out!
                      Me and my step dad's 1991 Accord EX Coupe MRT
                      82 accord-rip, 94 geo-sold, 82 cavilier-rip,81 civic-rip,88 accord- rip, 88 legend- rip, 91 civic- sold,97 geo-sold, 92 accord- sold 94 accord- RIP, 1990 Camry- RIP
                        I did a whole rear swap from an acura CL 2.3 coupe. Crossmember, big brakes, bigger sway bar than EX cb7. Just have to run the handbrake lines. The CL arms are a bit longer, which gives the car a slightly wider stance, and handles like a completely diff car. Pics in my mr thread.
                        My 91 Accord F22B DOHC MR
                        My 1996 Civic Ex H23A VTEC MR
                          The cl does not have bigger rear brakes
                          I couldn't really find any pictures in your MRT either of the swap. At least not anything recently.
                            Does it eat up rear tires because the rear is longer? Just a thought
                            Click For MRT
                              http://www.cb7tuner.com/vbb/showthre...=65297&page=10
                              Click For MRT
                                i was looking for this and thanks to a member i found it thank you guys
                                paypal info:leonardorivera50@yahoo.com
