IMAGES ARE BEING EDITED. I WILL HAVE THEM POSTED SOON.
So, I've read and heard it said that it takes 2 people to bleed a clutch. Especially concerning our cars I've seen this all over the internet. I've even seen people say it's truly a 3 person job. One person pumping the clutch pedal, one adding fluid to the reservoir and one working the bleeder valve.
None of this is true. I will show you here that you don't need anyone but yourself. It's easy and it's a lot faster than the standard procedure to do it by yourself. This is somewhat reverse of what you're used to. If you'd like to skip straight to the bleeding you can click here.
Requirements:
[IMG][/IMG]
-A Ratchet
-An Extension
-9mm wrench(I used an adjustable wrench. Not recommended though.)
-10mm wrench
-10mm socket
-12mm wrench
-12mm socket
-17mm wrench
-Needle-nose pliers
-A Phillips-head screwdriver
-Dot 3 Brake Fluid
Master and Slave Cylinder Locations:
If you don't know where the clutch pedal is. Lord help us all.
Requirements:
[IMG][/IMG]
-A Ratchet
-An Extension
-10mm wrench
-10mm socket
-12mm wrench
-12mm socket
-17mm wrench
-Needle-nose pliers
-Dot 3 Brake Fluid
