Vehicle: 1990-97 Accord / 1992-96 Prelude
Part: Weapon R coilovers
Provided by Weapon R
If you have further questions about our product(s), please
contact our technical support team at: Tel: (650) 992-9669
This Kit Should Include the Following Items:
2 X MAIN REAR COIL OVER SPRINGS
2 X MAIN FRONT COIL OVER SPRINGS
4 X KEEPER SPRINGS
4 X COIL OVER SLEEVES
8 X COIL OVER PERCHES
2 X ADJUSTMENT SPANNER WRENCHES
4 X MIDDLE SPRING ALIGNMENT PERCHES
4 X BILLET STRUT SPRING ALIGNMENT CAPS
4 X SETS OF PLASTIC SHOCK TO SLEEVE ALIGNMENT SLEEVES
Tools Recommended For Installation:
Socket wrench w/10mm, 12mm, 14mm, 17mm sockets
Spring compressor. Hex Wrenches
Coil Over Conversion Installation Procedure:
1. Jack up vehicle, making sure that the vehicle is secure on jack stands.
2. Remove wheels.
3. Remove shock assembly from chassis.
4. Using a spring compressor, carefully remove strut mount.
5. Decompress and remove spring from strut.
6. Remove dust caps & bump stops from strut assembly.
7. Install sleeve onto front shock, with unthreaded part facing down. (Front shocks only.)
8. Install sleeve onto rear shock, with unthreaded part facing down. (Rear shocks only.)
9. Install first perch (flat) onto sleeve and then install second perch (longer w/step).
10. Install appropriate plastic shock alignment sleeve in between the shock and aluminum collar.
11. Be sure that the plastic alignment sleeve is seated securly and wedged into place.
12. Cut off excess plastic alignment sleeve to the top of the aluminum collar.
13. Install Rear Spring onto rear Shock assembly, and on Front Springs on front Shock assembly.
14. Install Middle Spring Alignment perch onto top of main spring.
15. Install Keeper Spring onto top of middle spring alignment perch.
16. Cut Thickest part of the OEM Bumb Stops to 1" Tall.
17. Install billet aluminum spring alignment cap onto top of keeper spring.
18. Install OEM Strut Stopper washer onto each strut. (See Illustration)
19. Re-assemble the rest of the OEM Shock assembly & install shock onto chassis.
20. Pre-set perches to desired height, lock perches into place with Spanner wrenches.
21. Repeat procedure on other shocks.
22. Jack up vehicle and adjust perches til desired height is obtained.
Extra Lowering Options:
To maximize range of adjustment in rear, you may trim the outer lip of spring cup off. Make sure you have enough area left for the perch to rest on. Be extra careful when trimming shock cup -- do not cut into the shock body.
Product disclaimer:
1. Vehicles modified by competition parts may not meet legal requirements for the use on public roads. It is your responsibility to comply with Federal, State, and local laws prior to installation. Use or installation of competition products may affect your insurance and/or vehicle warranty coverage. It is your sole responsibility to comply with laws pertaining to competition products on public roads.
2. Weapon·R Competition Products assumes no legal responsibilities and/or liabilities, whether to your vehicle, engine/motor, person(s), and/or property(s), that result from the use of, or servicing of a motor vehicle of which this product has been installed, or to any other vehicle(s), person(s), regardless of whether or not this products has any involvement directly or indirectly and/or liability, and/or whether or not this product has been properly installed. The installer(s), user(s), and/or person(s) attempting to install and/or liabilities whether to person(s), property(s), yourself and/ or others. This legal disclaimer is acknowledged by person(s), user(s), driver whom install, drive and/or use this product. Whether or not this product is purchased, given and/or any other means of obtaining this product.
3. Returns are accepted only if all parts are in re-saleable condition, and no returns will be accepted after 30 days, and furthermore is subject to a 20% Restocking fee.
4. Installation of this product will act as an acknowledgement of the legal and product dislaimer stated herein.
4 X KEEPER SPRINGS
2. Remove wheels.
Product disclaimer:
