SUSP: Greasable sway bar bushing install
  • SteveB
    replied
    Originally posted by 93accordexcoupe
    steve what was the part number that fit ur rear ST bar? i found 20.5mm and 22mm. im guessing the 20.5 will fit if i grease it up and slide it on
    The bar is advertised as 13/16".
    Leave a comment:
  • 93accordexcoupe
    replied
    Leave a comment:
  • starchland
    replied
    I should pick that up, my front squeaks like an old bed, but I think its also hitting the chassis at somepoint
    Leave a comment:
  • SteveB
    replied
    steve is that ur rear ST sway bar? did the bushings mount to the same place that ur ST ones did?
    Yes, and yes.
    Leave a comment:
  • 93accordexcoupe
    replied
    Leave a comment:
  • SteveB
    replied
    Originally posted by cp[mike]
    i can see that fitting getting broken right off by road debris...
    Leave a comment:
  • cp[mike]
    replied
    Leave a comment:
  • SteveB
    replied
    No squeaks, possibly increased compliance.
    Yes, it's a zerk fitting for a grease gun.
    Leave a comment:
  • cp[mike]
    replied
    do you use a grease gun on that fitting to lube em up ?
    Leave a comment:
  • FishyMan
    replied
    Compared to home-made one. Actually did you notice any difference since changing to aftermarket ones.
    Leave a comment:
  • SteveB
    replied
    Originally posted by FishyMan
    Did you notice any difference in the handling? Did ur bolts get stuck when u replaced the OEM ones?
    Thanks.
    Compared to what?
    No.
    Leave a comment:
  • FishyMan
    replied
    Thanks.
    Leave a comment:
  • SteveB
    started a topic SUSP: Greasable sway bar bushing install
    Picked these up to get rid of an annoying squeak. Seemed to do the trick.
    $22.95/pair locally, ordered through the Keystone program at Canadian Tire.
    Installation is self explanatory. I specifically used the suffix G part number, for "graphite impregnated".
    Note the grease grooves on the inner surface.....
    My attempt of making my own...
    The real deal!
    Fronts installed....
    ...and rears.
    Energy Suspension link
