lokuputha : 1992 Accord EX-R
    Rims =
      Originally posted by King James View Post
      Do you have a rear sway for sale?.....if so what kind
      Also Im jelous of the cleanliness of your ride.....Im working my ass off to even get mine half as clean
      Plus rims look good
      Originally posted by True-BlueCB7 View Post
      Rims =
      X2 lol
      yeah James, I can give you the original EX-R rear sway bar. I am going to install the ST sway bar set soon enough.
      Drove to Orillia to pick up the OZ's. Got a combined mileage of
      7.58L/100km = 31.04 mpg US = 37.28 mpg UK
      I am aiming for 7L/100km = 33mpgUS with the up-coming mods.
      DEVOTE
      FS: Lokuputha's Stuff
        Good God. How'd you get such good gas mileage?!
          damn i was hoping you were gonna be selling the st rear sway haha.....I knew it wasnt likely tho.....thanks for the offer on stock sway.....I already have one tho
          Burrito Bandidos: It will change your fuckin life
            V .. you know Im down for whatever.
            Am I to assume those are OEM Lancer rims .... They didnt come from Kijiji did they?
            I was soooooo hoping you woukld get the Rikens though
            Members Ride Thread - http://www.cb7tuner.com/vbb/showthread.php?t=121452
            Originally posted by slammed4thgen
            dustin, you are a dick!
            officially the lowest ive seen now
              Function-over-form Dustin, function over form.
              I'll be adding the larger Vigor calipers up front, which are heavier. These wheels should lessen the unsprung weight. Plus, I can use a larger side-wall tire, which means better mechanical grip.
              Yeap, they are off kijiji.
              DEVOTE
                oh man V, I have always wanted a set of those rims...definitly one of my fave OEM style rims
                one thing I would check though...is Im not sure if the bigger brakes are gonna fit under those OZs...remember Gs OZ rims and how close his wagon brakes were to the rim...just something to think about
                be risky, be smart, and most of all be creative!
                  Gosh I have a soft spot for arcadia green cb7's.
                  99 GS300 (Aristo) 2JZ Power
                  Bought from:gdout, bb6-sh
                    UPDATE:
                    Just swapped over the OZ rims, during my lunch brake. They are 15x6 42mm offset, where as the CB's wheels are 15x5.5 50mm offset. Brake caliper clearance is 5mm, will have to see how the Vigor brakes fit.
                    Driving impressions: Lighter wheels means the wheels rebound a lot faster. This makes the suspension feel more planted. The feeling is all very subtle. There is a pronounced thump from the tires I can hear now; most likely due to the faster rebounding tire hitting the ground, I could probably inflate the tires a little more to cure this. Overall, the ride seems smoother and more compliant.
                    Solutions: Koni Yellows, Tein H-Tech springs, Suspension Technique Sway bars, new bushings.
                    Yeah Chris, even now, with the regular brakes, I have about 5mm of clearance. I will have to test fit the wheels before the brake swap. If the brakes are too big, I'll just slap the 240SX wheels on then, I really like those wheels.
                    You know what, now, so do it.
                    DEVOTE
                      MAD WEAK SON
                      Spark that bitch !!!!!
                      Kidding V ... I think for the price (yeah I saw them on there too) you couldnt miss.
                        Rims =
                        X2....
                          washed the car, it rained cats and dogs, but the car still looks clean
                          to do list:
                          -suspension
                          -patch rust and paint
                          DEVOTE
                            GOing to keep the green V?
                            ALso ...
                            Fixed it
                              car is looking great
                                ALso ...
                                Fixed it
                                O....M....G! that looks so proper.
                                I wonder how much work it would be to have summer springs and winter springs.
                                DEVOTE
