It was moving right along, and it was all very exciting for a bit there today. I spent a while working on getting the transmission in, but little things conspired against me. The hardware with the rear mount - there was so much dirt and grime inside the bolt holes in the subframe that the ESP mount uses that the EX mount doesn't, that it was fighting the bolts getting in. One started flattening its threads, but luckily I had a spare to work in and out to clear the gunk. And then I had forgotten that one of the bolts ESP supplied with the low-profile rear bracket didn't fit through the inner sleeve of their own mount, so I had to dig around for a replacement for that as well. And then as I was pulling the transmission up into place, the tight confines of the bay were in the way. First I took the slave cylinder back off, which made things easier, but then as the trans got higher, it was hitting both the front and rear subframes because of how far away from the engine it needed to be to clear the input shaft. It's making me appreciate the auto right now; that transmission goes up and down so easily with how the flex plate mounts flat against the converter. The front subframe needs to come down, though, so I'll be fitting the ESP traction bar sooner than expected. But for the second day in a row, despite three layers of socks this time, I was hurting too much from the cold and called it quits. Wish I had a garage at home, or I'd have somewhere warm to take breaks.
Anyway... yesterday, the rest of the new parts were installed on the trans and the Competition flywheel went on. ARP's B-series flywheel bolts are compatible with the F/H motors, in case anyone was wondering:
Today, the Duralast clutch was installed. That 19 lb-ft spec doesn't feel quite tight enough for a part like this, but okay.
If you don't remember my post from when I had some parts powder coated, this car's color scheme is all planned out and the entire engine bay plus a lot of the suspension hard parts will eventually be painted/coated this Toyota Quicksand-inspired tan. It's kinda funny how once it's all said and done, each of my engine mounts will be a different color. This one's tan because the subframe it bolts to will be tan. The transmission mount is silver to match the transmission, and at some point the driver side mount will be redone in matte black to blend into the timing cover. The ESP torque strut is left polished because I think it would look odd if it was colored, but who knows, maybe I'll decide to have it done in matte black as well in hopes that it'll 'disappear' from view when you're looking down into the engine bay. We'll see how the polished bar looks agains the clean H22...
I LOVE the ESP low-profile bracket. It's just so easy to get in and out!
'til next weekend...
