Interesting color choice... and you didn't like the blue interior why?
CyborgGT : 1993 Accord EX wagon
Originally posted by Raf99 View PostThat looks nice man. Quite the color mix, won't see that anywhere else haha. Also looks like you could sleep on that floor. A lot of work right there. The foam in the PS res means there's an air leak in the system I believe. There's different ETCG videos etc. on them trying to fix this, some never do and simply get a new pump. Assuming you had to top off the fluid implies there's a leak somewhere? And the wire..hmm not sure. Doubt it's for the japan version which has the 1 power function, and it's not the seatbelt. What's the color of the wires I wonder...
Originally posted by hiptech View PostInteresting color choice... and you didn't like the blue interior why?Last edited by CyborgGT; 01-27-2021, 08:34 PM.
Clutch issue solved, manual conversion done and dusted! It was a combination of a couple things: the bushing above (turns out my newer pedal arm did have one, it was just worn thin), and the pin it goes around, which was still from the bad pedal arm, being worn and slightly bent. I didn't notice the pin itself was bad until tonight, but I had a straight spare on hand.
I'm guessing that first bad pedal/pin combo was probably why that particular car was in the junkyard; maybe the owner couldn't figure out why their clutch wouldn't disengage and gave up on the whole car. A bushing gone bad led to constantly pressing too hard on the pedal to compensate, until the hole stretched out enough to mess with the master cylinder's travel.Last edited by CyborgGT; 01-31-2021, 01:15 AM.
Thanks! I'm feeling good about the progress made so far.
The power steering issue seems to have worked itself out. Tonight I wiped down everything in that front corner of the bay around the reservoir where it's been leaking since I bought the car, bled the crap out of the system, and drove it around the storage facility a bit. There's still some really light, surface-level foaming, but it's lessened a ton and I'm not seeing any new drips anywhere, so a good bleed must have been all it needed. I don't even remember looking at the fluid level at the time of purchase, so it may have just been overfilled. Once the engine's out and I detail the bay in preparation for the H (... ), I'll be sure to look for any evidence of bad connections, pinholes in hoses, etc.
*ED. - Alright, nevermind, it's still foaming over a bit. There's so much oil residue all over this engine bay, though, including behind the p/s pulley. I'll just go ahead with the H swap, with a new H pump on top of the bay detail/inspection, and see if that stops it. Also, I discovered that my wheels are rubbing on the traction bar radius rods at full lock. So much for getting them powder coatedLast edited by CyborgGT; 02-02-2021, 02:49 AM.
Soo my wheels also hit the ESP traction bar at full lock. I thought I was the only one. Using 17x9 rims on 215/40/17 (+38).
And the PS foam is an air leak in the system. I found the ETCR vid I was talking about. He had a leaky PS pump on his Honda Oddsey and rebuilt the pump. After the rebuild he gets foam in the fluid (31:26) due to air being introduced into the fluid. But he never did find out how or where the air was being introduced and suspected it was the pump o-ring somewhere / somehow. Even with Honda o-rings, same issue. He thinks is the suction side / the o-ring for the reservoir connector. He bought a new pump and fixed the issue, so the issue was the pump the whole time but he took it apart several times with different o-rings etc. , couldn't solve it. May want to save yourself a headache and just get a new pump, some may disagree with this advice and tell ya to rebuild of course...
https://www.youtube.com/watch?v=ArxN8T_6PbI
Originally posted by Raf99 View PostSoo my wheels also hit the ESP traction bar at full lock. I thought I was the only one. Using 17x9 rims on 215/40/17 (+38).
As for the wheel rubbing... I guess that's why the stock radius rods are curved. I doubt any traction bar company does that.Last edited by CyborgGT; 02-03-2021, 10:16 PM.
Originally posted by Rilas View PostMy Innovative traction bar doesn't hit at full wheel lock. I have about 1" between the edge of the radius rod and the crank pulley. I've never hit it though with the current suspension setup.Last edited by CyborgGT; 02-04-2021, 07:29 PM.
Finally, something. Just ordered an ECU with Hondata. I'd been saving up, but then realized the RSX needs new dry-weather tires.
I went ahead and got the full package from Phearable. Rebuilt ECU, S300 installed, and a Premium base map so I can make sure the engine's running smooth at home. In the event that PFI decide to film the tuning for their channel, I don't want my car being another one of their basket cases that needs a bunch of embarrassing work done before it's ready for the dyno. Especially since I've never missed an episode since they started, and I don't think they've ever had a CB on. Gotta represent!
Annoyingly, while ATI makes dampers for Hondas, they don't support proper installation of them. I got lucky on timing with a crank adapter that someone on IG made a small run of. Makes zero sense that ATI doesn't offer them, but at least I now have the full tool kit necessary for H and K (and F?) dampers.
I assume these are much better at dampening vibrations than the stock pulley. Passenger comfort and engine reliability are priorities this go around. I've decided that even the urethane mounts will be tossed once the bay is painted and I get a factory 5-speed trans bracket welded in; the ESP torque strut will still be there to help with throttle response.Last edited by CyborgGT; 03-30-2021, 01:59 PM.
[QUOTE=CyborgGT;n4977301]I'm really needing a cargo privacy cover, but no luck yet.QUOTE]
https://www.partrequest.com/auto-par...h-224407498068
If you're still looking, here is one I just ran across while looking for some other stuff, maybe a little rough though. Might clean up well?
