lowakkord : 1991 Accord EX-R
    ENGINE:
    1994 JDM H22a
    M2S4 H23 5 speed transmission. (swapped from automatic)
    ESP-NET Poly Auto to 5Spd Mounts (Black Inserts)
    Exedy Stage 1 Organic Clutch
    Fidanza 8lbs Flywheel
    Mahle 11.5:1 CR FRM Pistons
    Golden Eagle Standard Rods with ARP 2000 Studs
    Eagle H-Beam Rods
    ACL Rod Bearings
    OEM Main Bearings
    P+P'd Exhaust Side of Head.
    Skunk2 +1.0mm Oversize High Compression Valves
    Skunk2 Dual Valve Springs
    Skunk2 Titanium Retainers
    Skunk2 Billet Cam Seal
    Skunk2 Rad Cap
    Skunk2 Adj. Timing Gears (Red)
    ARP Head Studs
    Golden Eagle Fuel Rail with B+M Fuel Pressure Gauge and Regulator
    DSM Bluetop 450cc Injectors
    Optima Yellowtop Battery
    Taylor Battery Trunk Relocation Kit
    Koyo Rad
    12" Flex-A-Lite Electric Pusher Fan
    Glowshift Oil filter sandwich
    P/S delete
    A/C delete
    Cruise delete
    Wire Tuck
    Shaved Engine Bay
    SUSPENSION/BRAKES:
    Tokico HP Blue struts in the front
    KYB AGX adjustable struts in the rear
    Skunk2 coilovers (no sleeves in front, just springs)
    Megan racing rear short adjustable lower control arms
    Energy suspension polyurethane bushing kit (EVERY bushing in front suspension)
    Megan Racing Front Upper Strut Bar
    Earls Stainless Steel Braided Flexlines (For 93 ex)
    Rear Disc Swap
    Brembo rear cross-drilled rotors
    Kleen-Flo Dot 5 Approved Brake Fluid *Dot 3 now, 5 sucked bad!*
    No Camber Kits
    EXTERIOR:
    Spray bomb Primer.
    16" Advanti 5-Spokes *sold*
    Stock Ex Rims (Painted a Goldish colour)
    96 Spec Integra Type R wheels.
    JDM Blackhoused 1 piece headlights
    Red/Clear taillights
    92/93 front end conversion
    ex lip
    acura vigor lip
    5th gen lip
    5th gen Type R style lip *installed*
    Kaixen 6000K H.I.D's
    JDM CB3 Sidemarkers
    JDM parking pass
    JDM Bumper Pole
    JDM OEM 1 Piece blackhoused headlights.
    INTERIOR:
    -Swapped grey interior
    -New OEM Rubber Pedal Covers
    -JDM OEM foglight switch (no fogs yet, but i can pose right?)
    -JDM OEM Bumper Pole Switch
    -JDM OEM Dc2 ITR Radio Delete Cover (in C/F)
    -Oem ShiftKnob
    -Cheapy Gauges Retro-d into HVAC slot.
    -Custom Vinyl Wrapped Armrest. (Thanks Mom)
    -Proform Shift Light
    -1995 Prelude Seats (Not Installed)
    FUTURE PLANS:
    Hondata S300!
    Get it tuned and painted!
    JDMRIDES.ca
    JDMRIDES.ca
      Wow this is one hell of an Accord, great job man. I like the rear disc conversion too.
        VETTTY NICE START my friend..
        92 LX. A6 with GUDE bullfrog Cam. M2S4 transmission..Gutted H23 intake mani. The rest you will just have to find out!
        MR Thread:
          nice!!!!....very well documented....
          u should come to the next Toronto meet, when ever that is.....
          DEVOTE
          FS: Lokuputha's Stuff
            man i was planning on coming to the first, although i woke up sunday morning much later then i expected, and couldnt find directions ....and finally gave up hope....but i wouldnt have been in the cb7 anywho...so ill be there next time
            JDMRIDES.ca
              sign up here... http://www.cb7tuner.com/vbb/showthre...t=76207&page=4
              DEVOTE
                Wow bro definately a project ride...keep it coming and keep us informed..
                My Old Baby
                SOLD TO
                  great job ,keep up the good work
                  Hustle Hard! This is a design of some gear I've been workin on.
                    thanks for all the comments guys, glad you like the progress...theres plenty more to come!
                    JDMRIDES.ca
                      More been there done that pics:
                      August 2006, before it got completely ripped apart.
                      H22 coming home!:
                      JDM parking pass:
                      Body work...not really done:
                      JDMRIDES.ca
                        woww. nice.
                          i am curious if you have gotten any cel lights?? mine is an egr light and it seems to be unfixable,, but she runs harder than ever even with it on
                          "Self Renewed"
                            yes i have a cel light on, but i dont have an 02 sensor in yet, so that for sure is one reason why its on, ill need to hook a computer up to it for sure, did you use your f22 egr, or did you use the h22 egr?
                            JDMRIDES.ca
                              Originally posted by npor
                              woww. nice.
                              X2...
                              My Old Baby
                              SOLD TO
