Hello.. i hope someone can help me. I have a F23A1 long block with low miles and would like to put it in my 91 accord wagon that has a tired F22A1. can i use all of the parts from my F22A1 on my F23A1 block?
F23 swap
I moved this thread into the technical section because it is not an "off-topic" question.
There have been a couple threads on here that deal with this swap. It's similar to wiring up an F22B1 VTEC engine that came in the '94-'97 Accords.
I know you said it's low mileage but I want to know the other reasons you're wanting to do this swap. If it's for performance you won't find much more. This engine is not generally considered a performance engine. If it were me I'd just try to use the F23A1 short block and the F22A head. Read up on the threads on the site that deal with that swap though.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
Well My F22A1 has almost 300k on it and leaks and burns oil and i have little to no money and really need to get the car back on the road. I got the F23A1 for $100 and was told my Parts would bolt right up. Well Except the exhaust. and Where did you move my post i cant seem to fine it in Tech
Someone changed the title to "F23 swap".
Whomever told you that all of the parts from your F22A would bolt up to your F23A was simply trying to sell you an F23. The exhaust manifold, as you've already pointed out, doesn't fit as well as the intake manifold. I'll do more research for you in the morning but I think there's an issue with the oil pump that needs to be solved also. I'm not sure so I don't want to spout anything out.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
Its been done all info is here, you transmission, drivers bracket/mount, a/c bracket, and alternator bracket all bolt on. The powersteering will be different and has to be modified. the F23 and F22 engines use different timing belts, the f23 has a crank angle sensor, which you wont need, but you still need to keep the gear on the crankshaft.
The exhaust manifold on your f22 will not match up to the f23's head.
If I were you i would put the f22 head on the f23 block but replace the valve seals if you do so. This would require you to use a f22 timing belt since the f23 has a smaller head it uses a 112 tooth belt where the f22 uses a 113 tooth belt because of the larger non vtec head. The tooth count on both blocks for all gears, camshaft, crankshaft, waterpump and balance shafts are the same. This head/block combination will allow you to use your engine harness without modification, ecu, intake manifold, exhaust manifold, mounts, brackets and accessorys without modification.
For this you will need
F23 rear/front seal, water pump, balance shaft seals, tensioner, and head gasket.
F22 timing belt, cam seal, intake gasket, exhaust gasket, valve seal set.
Unsure but I think you use the f23 block timing cover, and the f22 upper timing cover.
Thanks IBCNYA. I knew the info was here but I was posting from my phone.
I wish this hybrid swap was done more. These engines are increasingly common in the junkyards now and typically have much less mileage than the F22As we have. With the additional stroke that will allow you to run more duration on your cam and the ability to add K20A2 pistons for a 11.4:1 compression ratio you can't go wrong.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
to simplify a bit, back when i had the f23a4 in i was able to use allmost everything from an f22b1, i switched to the b1 intake manifold to eliminate the 3 wire iacv issue, used b1 TB to retain the thermo valve to keep from pissing the iacv off. used the b1 exhaust manifold as well. timing belt, tensionor, seals, valvecover (cause i wanted to use the simple "vtec" VC). Just a bit of what i had set up. hope it helps.Originally posted by IBCNYA View PostIts been done all info is here, you transmission, drivers bracket/mount, a/c bracket, and alternator bracket all bolt on. The powersteering will be different and has to be modified. the F23 and F22 engines use different timing belts, the f23 has a crank angle sensor, which you wont need, but you still need to keep the gear on the crankshaft.
^best part is you can pick em up for like 350 already pulled in most places with only 60-80k. gotta love itOriginally posted by Jarrett View PostThanks IBCNYA. I knew the info was here but I was posting from my phone.
I think he would have to use the f22b1 dist and ground the IACV (the third wire) other than that I think you covered everything. Oh and use a F22b1 ecu obd1 of course.Originally posted by IBCNYA View PostIts been done all info is here, you transmission, drivers bracket/mount, a/c bracket, and alternator bracket all bolt on. The powersteering will be different and has to be modified. the F23 and F22 engines use different timing belts, the f23 has a crank angle sensor, which you wont need, but you still need to keep the gear on the crankshaft.
And jarrett is right. And that is exactly what Ill be doing with my car. Fuck it why not? No need to be a speed racer just budget accordingly.
