i bout they'd have the same part numbers. the f23 gear has arms that work with the crank sensor.
F23 swap
According to IBCNYA the gears have the same number of teeth. The difference comes from the shorter height of the VTEC cylinder head casting that spaces the camshaft timing gear down lower just a slight bit. If you did the F22AX head onto the F23 block you're eliminating the only difference between the timing characteristics of the F23A1 and F22AX, hence why you just stick with the F22AX timing belt. He's done that swap and an F22B6 swap so he should know the peculiarities of them.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
