HONDA / ACCORD / 1991
12volts white + ignition harness
Starter black/white + ignition harness
Ignition black/yellow + ignition harness
*Accessory yellow + ignition harness
Power Lock black/white - lower drivers kick
Notes: The station wagon uses green/white for lock and yellow/white for unlock. These wires are found either in the drivers door harness or under the rear seat.
Locate the large harness in the lower below the carpet in the drivers kick panel. Near the foot rest you will notice a piece of blue tape attached to the harness itself. Reach around to the underside of the blue tape to locate a 2 pin gray plug with the lock and unlock wires attached to the plug.
Power Unlock black/red - lower drivers kick
Parking Lights+ red/black fuse box in dr. kick
Door Trigger black/white - brown plug left of column
Trunk/Hatch Pin green/black - green plug left of column
Tachometer blue AC distributor
*Brake Wire green/white + at brake switch
Horn Trigger lt. green/blue - column or horn relay
Notes: High-current ground. Use a relay when interfacing with this circuit.
This wiring information is being provided free of charge on an "as is" basis, without any representation or warranty. It is your responsibility to verify any circuit before interfacing with it using a digital multimeter.
Directed electronics, Inc. assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
"*" is basically only for remote start, and not for a standard alarm.
Enjoy.
Enjoy.
