i have an oil leak and i am scared it may be my head gasket. it is a pretty significant leak because after i drive it, it leaves a medium size pool of oil in my parking spot. i can also smell it because it is dripping onto the exhaust near the o2 sensor. i just replaced my lower spark plug seals but i don't think this had anything to do with it. here is a pic. this is the rear driver's side corner of the head. how much should this cost to fix, and what all needs to be done besides replacing the gasket? i don't think i will have the car too much longer, so i really want to know how much i should expect to pay for just a head gasket replacement.
Is it my Head Gasket?
That'd be an assload of oil to make it out of the upper cover. Hell yea, pull that upper timing belt cover off and see if there's oil all over the cam and timing belt. That'd be nuts...that's a lot of oil.Originally posted by mrhonda
I seriously doubt its the head gasket. I personally have NEVER seen a CB7 leak oil from the head gasket. It looks to me like the cam seal is leaking.
i was actually thinking of the camseals as a possibility. i will pull the cover maybe tomorrow. i was thinking, maybe since i replaced the lower spark plugs seals, and they were leaking, that i may have diverted the oil to leak somewhere else. it had always been leaking a little in this area, but never this bad.
Oh I've seen most of them leak alot MORE than that.Originally posted by Slateboy
That'd be an assload of oil to make it out of the upper cover. Hell yea, pull that upper timing belt cover off and see if there's oil all over the cam and timing belt. That'd be nuts...that's a lot of oil.00 Jeep Grand Cherokee 4.7 V8 4X4
92 Honda Accord LX
95 Honda Civic CX
Sounds like a distributor O-ring to me.Former: 90 Accord EX Coupe, 93 10th Anniversary in Frost White
1985 Volvo 245 manual [IPD lowering springs, IPD sway bars, OEM Virgo wheels, 1977 quad round headlights, 1978 grill]
2001 Mazda B3000 SE 4x4 extended cab [stock except for CB radio]
2008 Ford Escape XLT [bone stock]
2015 Toyota Prius Three with solar roof [rear diffuser, Vision Cross wheels... cheaper than steelies!]
its either the valve cover gasket,,, cam seal,,, or the oil preasure sensor. this is what goes bad on our cb7.
but non of the above its going to cost u $700 to $900 for parts and labor. lol for $1000 u can get a complete engine work. with piston righs replacment a valve job etc. lolare we there yet are we there yet are we there yet
check the cam seal first cause that looks and sounds identical to what my car did when I blew my cam seal... cost me about $400 to get it fixed but oh well
OS^e
1993 Honda Accord LX Coupe
My Members Ride's Thread
StickyDilJoe: "JDM may be a fad, but making your car look like shit... thats forever"
it was the camseal. i pulled the valve cover and timing belt cover. the belt is very oily. i also pulled the rocker arm assembly and resealed that and sealed the camseal with liquid gasket. it actually stopped the leak. i do need to take it to the dealer to get the timing belt replaced along with the cam seal. it sucks though because i just had it done around 40k miles ago, but they didn't replace the cam seal.
p.s. is the oil sensor the small plug thingy that looks like it screws into the back of the engine above the oil filter approximately?
