Easiest method of Interior Footwell lights
This was pretty much the first "mod" I did on my car and it's one of my favorite. It gives the inside of the car a completely different feel at night. I've looked around at other's lights and setups and I still feel that mine is the simplest so this is what I'll go with.
Tools and Parts needed
Wire stripper - Most Wire strippers have a cutter and crimper on there. You'll need those as well if your Wire stripper doesn't have those on it.
Inline fuse - I bought mine at Walmart, I'm sure you can find them at Autozone - Image
2 amp fuse - Fuse to put into the inline fuse slot.
Switch - Also bought this at Walmart for $1.25. You can also get 'em at Autozone for like $8.00 - Image
Wire Couplers - Like $6.00 at Walmart for 40 of them. Make sure they'll fit the gauge of wire you get. - Image
Wire connector caps - Used to connect 2 wires that are too big for the couplers. You'll only need 4 or so of these. - Image
Wire to plug Adapter - You'll need a few of these. You can get these at the same place as Wire couplers. I'm sure this has some better name, but refer to the picture to see what I mean. - Image
Something to mount with - You'll need something to keep the lights mounted where you want them. You could use metal U shaped brackets, but I personally just use Gorilla tape. I don't like drilling holes in my car and I have yet to have the gorilla tape let go of my lights. Whichever route you want to take is up to you.
40 ft of wire - $6.00 or so from Walmart. I used 16 gauge Wire I believe. There's no way you'll use 40 ft but It's always better to have more than less. Plus it's pretty cheap.
LED Footwell lights - These are the ones I use. I like them because they throw enough light for it to be fun, but not to the point where it's distracting while driving or noticable to the police car right next to you at a stop light. https://www.euroeffects.net/4-43-_LE...Tubes_2x6.html I use the 2x6 ones. If you want the 2x9 ones they're the same price you can order them right off that same website.
