whats the best ecu to use with the ecu and does any one knw how much it is to get the ecu chipped
ecu to use with f22a6
The best ecu to run with the A6 motor is the rite ecu for that motor, there's no point in chippin ecu's for a stock motor
Once a cam is added and bigger Injecters, or even a upgrade msd kit for your ignition, then a chipped ecu will have its benefits, some 1 correct me if I'm wrong
Stock A6 Ecu is the PT6. And it can't be chipped.
You will need to use a P28 or PO6 for chipping
As above, chipping a stock motor, will have minimal gains, unless other work is carried out as well. Just remember that each time you add a new engine mod it will need to be rechipped to make the most of the mod.
My 5.7 LS1 Holden Ute
oh wow i neva new that after ever mod the ecu has be rechiped learn something new er dayOriginally posted by evil_demon_01 View PostStock A6 Ecu is the PT6. And it can't be chipped.
As above, chipping a stock motor, will have minimal gains, unless other work is carried out as well. Just remember that each time you add a new engine mod it will need to be rechipped to make the most of the mod.BK ALL DAY
You will still be able to drive the car, Just you will be able to gain extra hp by getting it rechipped/remapped again.Originally posted by bk92accordex View Postoh wow i neva new that after ever mod the ecu has be rechiped learn something new er day
The best way to do it would be to, do all the mods you want - intake, exhaust,cam etc THEN get it chipped.
If you were looking to go into more extensive mods - Full NA or turbo, then using a remappable ecu is the best option
exactly...thats why you get parts....sit on them until you have all the parts NEEDED and WANTED...then install...then chip...then tune.Originally posted by evil_demon_01 View PostStock A6 Ecu is the PT6. And it can't be chipped.
it makes no sense to waste money..rechipping and retuning..by slowly putting on parts.
get all the parts...then chip and tune.
you want to do your tune while you're at a dyno session.
say for example...you got it chipped because you have a gutted H23 intake mani and 262 cam ( which is not much different than a A6 cam )..full exhaust ( engine back )..and you retard the ignition timing a little ...and you chip a PO6 ecu and get it tuned...
it will run to those mod specs.
now...if you get a bigger cam ( 272 or the huge 282 ) and get a higher rated fuel pump and injectors...the car WILL NOT run right...especially with that huge 282...be lucky if it even runs. But, with that 272...you will run RICH ...really rich..and you will lose power...might even backfire because of the wasted fuel. ( a fast way to blow out your cat )
then you get it rechipped and retuned...you will notice a HUGE difference in power...why, because now the rechipped ..retuned and remapped ECU recognizes the extra fuel being dumped in from the bigger cam lobes, injectors, and fuel pump.
IMHO, Id get all the parts...get EVERYTHING needed and wanted. THEN install...chip and tune.Last edited by SN2BH22CB7; 09-07-2008, 05:15 AM.92 LX. A6 with GUDE bullfrog Cam. M2S4 transmission..Gutted H23 intake mani. The rest you will just have to find out!
MR Thread:
http://www.cb7tuner.com/vbb/showthread.php?t=174586
My tribute page: http://www.cb7tuner.com/vbb/showthread.php?t=70489
