so I have a lx header and I get a cel when i put my a6 ecu(ex) in. its the o2 sensor code. so when i put my a1(lx) ecu in I dont get the code. So im guessing its because of the placement of the o2 sensor being the lx is higher up then the ex. so is there a way to run a a6 (ex) ecu with a a6(lx) header without it throwing codes. Reason is I dont like the speed limiter on the lx. (115)
a1 ecu in a6 posted before but info i got was untrue. . .
that shouldnt be true at all.
what code u throwing, 41? im throwing that right now but only with the new o2 sensor....the old one never threw it...
though when i swaped the ecu it was fine....
thats weird...wait for some more responsesWhat makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
I'm confused, or maybe not...so the PT6 doesn't have a govoner? What changes would you have to make to the car to remove the speed limiter entirely?2DAO (2 Door Accord Owner)
JDM H22 DOHC 200/161 2.2L
My members ride: http://www.cb7tuner.com/vbb/showthread.php?t=20385
ok i went to the junkyard. ask to try a ecu and they let me. so i tried an lx ecu. and guess what no code. then i put my lx back and still no code. then ex goes in and theres the code. next ex goes in and the same code. so im so
why would i change the sensor or wiring if i only get codes with certain ecus
if i get a vaild code on the ex ecu the same should happen on the lx if they all are interchangable
Yes, the DX/LX (both f22a1) had the O2 sensor on the manifold itself. The EX (f22a6) had the O2 sensor on the downpipe by the oil pan/cat. The f22a4 (in 91 EX I believe) I'm not 100% sure about.Originally posted by PRIMOCB7isn't there a difference between the dx/lx O2 sensor vs. the ex O2 sensor ??? the ex being a heated(4 wire) O2 sensor ???
I think you're right about the heated O2 sensor on the EX's w/ f22a6.
Dan
when i had the a6 many moons ago, i had to replace the O2 sensor. went to Honda and that was how i found out that the ex O2 sensor was a heated sensor. what that means, i don't really know
but i know for a fact, it cost more, around $150 as opposed to $90.
5.6L V8 32V DOHC
JDM HERITAGE - US BUILT
