Good morning cb7 I'm in the process of replacing my heater core . So my dash has to be removed I have the whole dash slipper
A loose but, I have ran into a problem removing the steering wheel , there are 4 screws going in from the back side of the wheel 5 if you have cruise control I have removed all of them but I can not figure out how to get to the 4 screw s that hold the horn button on? I have seen some members have said drop the steering collum but the whole in the lower portion of the dash is not big enough to slide the wheel threw how do I remove the wheel? And is it easier to just pull the whole steering collum wheel turn signals ignition and wiper switches as a unit?
