So looking for some experienced help. From taking the old power booster out and putting the new one in I had to adjust the rod all the way in. Now with the new booster in the car nothing is set properly.
Can someone show me a picture of their adjuster nut/lock nut/pedal rod position under the dash?
I think I almost have it set correctly. The adjuster nut is all the way near where the threads end (closer to the pedal connection), but i still have about 1/4" until the master cylinder will make contact with the firewall without having to push the plunger in some. As per the manual with the pedal connected to the rod I adjusted the 17mm nut after loosening the "star" lock nut.
Now I have some lines and clear tubing attached from bench bleeding it, so i can see when I'm pushing the plunger in as I try to push it closer to the firewall. But I think I am correct that the plunger should not push in at all when tightening it to the firewall. (0mm - 0.0016mm clearance).
Thanks
Thanks
, to this
, to this.....
