Well, installed my downpipe today, hooked up O2 sensor, started the car, set the timing to 16, and let it run for a while, now that I can actually let the car idle without waking up the whole neighbourhood!!
Couple of problems that I ran into..First and foremost, car seems to be running super rich, 'coz the whole time my motor is running, I have black smoke coming out of my muffler..
Now, on the MAP control box, there are 5 vacuum lines:
- 1 for EGR
- 1 for charcoal canister
- 2 for intake manifold
- 1 for TB (on the old F22A1)
I hooked up all those, EXCEPT for the last one, since H22A TB doesn't have a vacuum line..SO! At first, I hooked up that line to the intake mani as well, and that caused a big surge when idling, and a lot of hesitation when I rev it..
I then unplugged that line from the intake mani, and the car idles steady, but REALLY low..I'm talking 200RPM or less..It stalls at times..I tried turning the idle screw, but after a couple of full turns, the idle is barely climbing..Didn't want it to turn anymore and screw something up..My question is, where am I supposed to hook up that vacuum line on the H22?
Second question is about my injector resistor box..I relocated mine, using an aluminum bracket...I just want to know if that box is supposed to be grounded or not?
My FPR gauge is showing a constant 41-43PSI, since I'm still using a stock FPR..
But anyways, I still don't understand why my car is running so rich..Constantly blowing black smoke, even backfiring at times..Any idea, input, advice, suggestion? Please help guys, I'm not too good at analyzing this kind of stuff..
Another thing I'm worried about is that my rad fan won't come on! The temp started to climb after a while, which got me worried..There's nothing wrong with the wiring, but the engine ran pretty hot today..OH! And my e-brake light on the cluster is not working for some odd reason!!! Hahaha oh boy, so many things..I'm not getting any code from the ECU though!! Either that or the jumper cable for the ECU code is just not working
I just hope this isn't caused by a bad ECU..
But anyways, any input from you experts will be highly appreciated...Thanks in advance!
Ronald
- 1 for EGR
I just hope this isn't caused by a bad ECU..But anyways, any input from you experts will be highly appreciated...Thanks in advance!
Ronald
STill having problems with the MAP control box tho..
Can't wait for this motor to be running 110%!
