Intake Manifold F22A1
    the intake manifold is not sucking in air. i have to leave the PCV hose open so that the motor would run.
    i redid the timing and its perfect.
    what are the possibilities that the intake manifold is not sucking air
    There has to be air going through the intake manifold in order for the car to run (air go into the cylinders+fuel=combustion blah blah blah). Taking off the PCV line from the top of the head will not get air into the combustion chamber by the way. Maybe your air filter is plugged??? Maybe that is what is causing it, the air filter is plugged and not allowing enough air to go through. There are many more possibilities like vac leaks for instance. Maybe a vid or a little more description of the problem would help us to help you.
    Originally posted by 92jdm
    if you have any mechanical inclination, it should be easier than a drunk highschool girl after prom.
      engine runs with the intake taking out. but if you step on the gas its not sucking in enough air. when you step on the gas and put your hands by the throttle body you cant barely feel air being suck in.
      you cant even rev pass or close to 2k on the rpm.
      it will stumble and then die afterward if i step on the gas.
        So if you open the throttle by hand with the intake tube off, the car will stumble and die? If so, that is not an intake or throttle issue, that sounds more like a fuel, spark or clogged exhuast issue. As for having to unplug the PCV for your engine to run. That sounds like your IACV is toast or extremely dirty.
        Is your check engine light on? Did you unplug ans sensors lately, maybe the TPS & MAP sensor connections got switched???????
        MR Thread
        GhostAccord 2.4L Blog
        by Chappy, on Flickr
          check engine light doesnt go on. no sensors are taking off. IACV is clean and a new one as well. i am getting fuel cause i replaced the fuel pump as well. and getting spark too.
          but i think i will be taking the cat off to see if its clogged and if its the problem. i do hear a hissing sound coming from the cat.
            Check your O2 sensor, and try and tighten your throttle wire that is on the throttle body.
            maybe it is lose.
            You can also do a seafoam job it might clear out any carbon that is obstructing the path to the engine.
            Temp sig, cars almost done
              maybe it is lose.
              one it would never be the throttle cable
              two i dont need seafoam
              three the cat was clogged and problem solved so i hollowed out the cat instead. i have no emissions over here.
