GhostAccord : 1996 Honda Accord EX
    ENGINE, 2.4L F22B2/A6 w/Individual Throttle Body Induction
    EXTERIOR, In process - Highly Modified - Images and specs to follow
    INTERIOR, In process - Fiberglass w/Race Trim - Images and specs to follow
    SUSPENSION/WHEELS - Race Modified - Images and specs to follow
    AUDIO/ELECTRONICS - 1996 JVC cassette deck with a couple beat up 6x9's..... anything that won't be loud enough to hear over the sound of my engine!
    FUTURE PLANS - Lots, stay tuned and you can see for yourself!
    Well I broke down and finally decided to add a members ride thread to CB7Tuner for my aptly named "GhostAccord" Build. I will most likely post up the initial information about the build and then post small link/posts when I do my blog updates. Hope that's OK????
    I will skip the beginning, as I started with a set of 01 GSX-R1300/1000 throttles that ended up being way to small for my engines specs. 46mm throttles are a bit small for a 2.4L engine. So I decided to use a set of Ducati 999r (shower top) throttles. I had to buy 2 sets as the Ducati is a twin..... 54mm at the throttle plate will be perfect for my build.
    by GhostAccord
    Base
    Model - 1996 Honda Accord EX
    Engine - 2.2L SOHC Non VTEC I4 (F22B2)
    Body - Sedan
    Colour - White
    Build
    Engine
    Intake Manifold/Induction System
    • Ram Air Hood
    • Fiberglass Air Box
    • 4 x 54mm Ducati 999r Shower Top Throttle Bodies
    • Custom F22A* Intake Flange Adapter Plate
    • Thermal Gasket
    Ignition
    • K24 COP Upgrade
    • Custom Engine Position Module
    Fuel System - 2 Stage
    • DeatschWerks 300LPh Fuel Pump
    • AEM Fuel Filter
    • -AN Fuel lines
    • Stock F22A Fuel Rail
    • AEM Electronic Pressure Sensor
    • 1st Stage - Port Injected, DSM 450cc Peak & Hold Injectors
    • 2nd Stage - Shower Top Injected, 240cc Ducati Saturated Injectors
    Cylinder Head & Vale Train
    • KMS Titanium Retainers
    • Manely 7° Locks
    • KMS Valve Springs
    • Custom Ground Camshaft (Delta)
    • AEM Camshaft Gear
    • 34mm Ferrea Intake Valves
    • 30mm (+1mm) Ferrea Exhaust Valves
    • Race Port & Polish
    Block
    • Modified F22 Oil Pan (Tucked for header clearance, and stretched for increase oil cap. & baffles)
    • F22A6 Stock Windage Tray
    • Stock F22B2 Oil Pump
    • ARP Main Studs
    • OEM Honda Bearings
    • Carrillo H22 Pro A Rods
    • Wiseco Custom Slipper Skirt 89mm Pistons
    • Darton M.I.D Sleeves
    • ARP Head Studs
    • Cometic 89.5mm MLS Head Gasket
    Header & Exhaust System
    • MAC Kustoms Tuned length, 3 Step, 4 - 1 header w/Merge Collector
    • KTeller Mandrel 3" Stainless Pipe Kit
    • Magnaflow Resonator
    • Vibrant StreetPower Stealth Muffler
    Cooling System
    • -AN Braided Hoses and Fittings
    • Yonaka 2" Core 1/2 Rad w/FFC Billet Mounts
    • Maradyne 13" Slim Fan
    • Meziere 35gph dual stage Electric Water Pump
    • H22 Thermostat Housing/remotely mounted
    Transmission & Clutch
    • Stock F series Trans
    • Quaife Helical LSD
    • Fidanza 8.5lb Aluminum Fly Wheel
    • Fidanza 2.3/4 puck clutch kit
    Suspension & Steering
    • DIY Manual Steering Rack
    • Energy Suspension Poly Bushings Front and Rear
    • Suspension Techniques Front and Rear Sway Bars
    • KYB AGX Struts
    • Skunk2 Racing Springs
    • 17" Drag DR19 Gold w/Cooper 225/45R17 tires.
    Brakes
    • Xenocron Brake Booster Delete Kit (w/Wilwood Brake Master Cylinder & CNY Performance aluminum adapter plate)
    • ROH V6 Caliper and Rotor Upgrade
    • Stainless Hard lines w/Wilwood braided flex lines.
    • Rear Disc Swap
    • Adjustable Proportioning Valve
    Body
    • Xenon 4pc kit
    • Ram Air Clam Shell Hood
    • Shaved rear doors and trunk
    • Active Spoiler
    • Rear Fender Flares
    pics to follow!
    MR Thread
    GhostAccord 2.4L Blog
    by Chappy, on Flickr
    Intake Manifold & Throttles
    GSXR 46mm vs Ducati 54mm
    Go to my blog for the full Build
    Ignition
    Engine Position Module (EPM) made out of a stock F22 Distributor.
    Coil Over Plug (COP)
    This is the original setup using Suzuki pencil coils. My new setup is the same configuration only it is using the smart coils from a K24 Accord.
    F22A6 Cylinder Head Porting
    Intake
    Exhaust
    Combustion Chamber
    Valve Train
    Engine Block
    Sleeves, Rods and Pistons
    Polished Pistons
    Waiting to send the block and all its parts out to the machine shop soon!
    Header
    As it sits now.....
    Exhaust
    Cooling System
    Yonaka 2" Core 1/2 Rad w/Maradyne 13" Slim Fan
    Decided to make up an aluminum bracket for mounting the slim fan...zip ties aren't as cool as people think!
    Fan itself never touches the rad and it is mounted using rubber isolation bushings
    Remote H22 Thermostat
    This will be mounted somewhere on the frame rail.
    Drilled and tapped for AN fittings
    Next step is welding 20 AN bungs onto the inlet and outlet. I will be welding all of my aluminum components at the same time...
    Fresh paint and busings
    Swaybars and brakes
    MR Thread
      and More.......
      MR Thread
        Even though you are going to do most of the detailed updating in your blog, I hope you populate your summary posts here with pictures
        MRT
        14.38 @ 98.66mph
        Current fastest Laguna Seca Lap: 1:52.346
          Oh there are lots of pictures to come. The two reserved posts are for images.... �� I have to take some time to go through them all first....
          MR Thread
            In for pics...don't make us wait.
            YouTube Clicky!!
              Updated with a few pics in second post. More to come!
              MR Thread
                Very nice! I love that DIY EPM!
                Formerly 91AccordExR33
                11.68 @ 127mph
                417whp/375wtq
                Sold: 8/2016
                  Oh...my...it...is...alive
                  The Ghost shall haunt once more!
                  We will all be here from now on!
                  MRT
                  14.38 @ 98.66mph
                    What is it with companies creating shipping labels and then taking 5-10 days to actually deliver the item to the carrier? Do they think that consumers don't notice this? Also, don't blame the snow storms in the North East when you are delivering out of the South West ether.... I got that one last week.
                    If an order/item isn't ready to ship, tell me up front, I'd be OK with that! Better than trying to make it look like they shipped next day. When they had no plans to do so. /rant
                    Back to the build........
                    MR Thread
                      Few more pictures posted up!
                      MR Thread
                        Finally....... the rest of my exhaust showed up from KTeller today!
                        3" stainless pipe, Magnaflow resonator and all the hangers. It is a really nice kit they put together. Well worth the wait!
                        Now, I have a week off before I go back to work. Wonder if I can squeeze some Accord love in there somewhere.......
                        MR Thread
                            Yes! Yes you can love the Accord!
                            I've got that Magnaflow resonator, just 2.25". It's pretty loud on the streets. I imagine your setup is going to be much louder!
                            MRT
                            14.38 @ 98.66mph
                              What? .......
                              Did you post the rules because I used 2.4L as my Model and ITB as my trim in the thread title? To be honest there really isn't much CD5 or EX left of this thing, it's completely custom!
                              MR Thread
