F22a6 wont go past 3000k
    Ok so heres the deal. Its a 93 Accord 5spd EX
    Nothing has been swapped or messed with. The car looks like it hits rev limiter when you downshift a gear to raise the RPM higher or in that same gear.
    Now if you shift under 3000k the car picks up its normal speed on any gear.
    Its only when your at WOT that it hits that 3000k and wont go beyond that.
    There is also no check engine light.
    Prior to what i decribed is that when ever your getting up to speed around the 3000k at WOT it sounds like the CAT rattles. Not actually sure its coming from that area but it sure does sound like it. I tried and did visual check on the CAT after driving it hard and it doesnt show any glowing red looks.
    The engine dosent smoke,tick,rattle or anything it runs smooth.
    Any help would be appreciated.
      whats your tach look like? does it bounce around at 3k?
      COUPE K24
        although you don't have a CEL try to pull a CEL code anyways
        If the light stays on solid then you have a bad ECU
        If it flashes once with the key and then turns off you have another problem
          Yes it just bounces like it has a rev limiter at 3000k.
            Ok i will do that.
            But lets just say its not the ecu. What could it possibly be?
              Any more inputs?
                7 posts, and 5 of them are you... this thread should be deleted for that reason alone. Be patient. Nobody wants to help someone who is so anxious that they CONSTANTLY bump their own thread in a single day.
                It sounds to me like your cat is clogged. The higher you rev, the more exhaust you're pushing out. If the engine can't push the exhaust out, it won't rev any higher.
                  Deev, I do apologize if i overposted there not my attentions. I am just trying to get as much info on members who can point me in the right direction.
                  To be honest the CAT was my first guess but shouldnt it turn hot red after driving it for awhile?
                    By posting repeatedly, you're telling everyone that you're probably going to be a pain in the ass if they try to help you... so they don't bother. The only help you'll get is from people that don't know enough to help you.
                    Yes, the cat would usually get very hot. I don't know if that's always the case, as I have no personal experience with it.
                    Does your CEL work? I've dealt with many people that swear they aren't throwing a CEL, and it's because the bulb has burned out.
                    How about your ignition timing? Is it set properly?
                      Like i informed earlier i do hear a noise more like a rattling noise that almost sounds like its coming from the CAT area when you get up to the 3000k mark at WOT.
                      I believe the CEL works. Since it turns on when you turn the key.
                      I have yet to try and jump the connector to get a code. But the CEL light is not on.
                      Engine Timing should be correct since i compared all the points and marks to that of another accord f22a6 all visually checked.
                      I have looked around some other websites about the similarity of the problem and have come up on the TPS not working.
                        you could take the cat off and ride around to see if there is a difference. they can make a ball bearing type rattling (like you described) when they come apart inside. later.
                        Avoiding dirt at all costs
                          How old is your exhaust system? I had a similar problem in a Dakota back in the day where the cat was clogged. Basically all the honeycomb material inside crapped out and went to pieces. The truck wouldn't rev up past a certain range, it felt slow and you could hear a rattling sound down there.
                            Im pretty sure its the cars age but im not 100%. The piping as well as the CAT look to be in pretty good shape no rust at any point.
                            The only other problem it has is a intermittent working speedo. But i doubt that is whats causing the problem.
                              you can't look at the cat and tell if it's bad, the problem would be on the inside. you will not get a cel for a bad cat.
                              you can however hit the cat with your fist and hear something inside rattle.
                              when you said that your speedo works intermittently, that is probably your vss going out, but that wouldn't cause the problem you are having. eventuallly you will get a cel for that. later.
