hi i was wondering; i read a tread on hondaaccordforum that said a tsx or rsx 6speed trans would b able to bolt on a f22. true or false?? if its true would it give any type of gain?? shifting would be off?? itll be pretty koo 2 kave a f22 6speed uniqueness
6speed trans on f22??
http://www.cb7tuner.com/vbb/showthread.php?t=138029 <-mrt
diy whore riiittteeee here
[URL="http://www.cb7tuner.com/vbb/showthread.php?p=2208455"]
http://www.b20vtec.com/forums/members/pr3pg4lyfe.html
they're probably speaking of mating the k-series 6speed to an f22c or f20c in a fwd configuration. not an f22a which has nothing in common with an f22c
My Members Ride Thread
Originally posted by deevergoteYou have to think outside the box to get IN the box!
I don't know about a K-series transmission on a H22. (There are no H2K transmission kits....)
If you have the $$$ and were on a special race team, you could do something similar to the Japanese Touring accords. The famous Jaccs accord utilizes a H22a engine with a reverse head. This special engine is also mated to a 6-speed tiptronic transmission. I imagine since it's a H-motor... it may be possible that with enough work to the F22,if it's possible the head can be reversed the same way, it may fit the special 6-speed transmission. But besides reversing the head to fit that particular tiptronic transmission, a regular plate adapter may be possible to utilize a k transmission or possibly another cars transmission for instance a "corolla" etc. It's been done where cross platforms use different transmissions to create a different kind of beast too.
There was a project IS300 with a GS400 engine swapped into it that had a special transmission adapter built just for the transplant. Also look at the homemade skyline with the M45 V8 engine swap. If you have the $$$ you can build wonders and have a special transmission and or car tailored to your liking.Last edited by Kurobei; 05-29-2009, 04:38 PM.I need a custom turbo manifold built....
707 NorCal NinjaZ
Honda Twincam Motorwerkz?"I am the Yakuza CB7!"'92 Accord Sedan SiR
Originally posted by Kurobei View PostI don't know about a K-series transmission on a H22. (There are no H2K transmission kits....)
So that being said....
Is it feasable with an H swap?
Bought from: TypeG,mak,CB7_ACCORD,ChampCoupe,Blackex
Traded with: Cb7xChun
Sold to: Rob_is_legend,DaddyO,daheavyking
Sedan MR Thread Coupe MR Thread Prelude Si MR Thread
My huge For Sale Thread
There is alot to modify if a regular person wanted to "reverse their head" on their block......it's not as easy as flipping the valve cover the other way.
I just wanted to point out that a 6-speed is possible on a H22 motor and since stockwise transmissions can be interchanged between F and H motors, I imagine a 6-speed will be highly possible on a F22 motor... i mean comon' why not?
I just think that $$$ wise it won't be worth it unless your someone like Bisimoto and have the funds or will power to even fuck with a F22 motor in that territory. Thats why i mentioned the possibility of a adapter plate similar to the H2B (probably cheaper than reversing the head), but then again finding a oem 6-speed that will adapt to a older engine might be quite a challenge. If a H2K adapter is possible, there would be a kit most likely for civics and integras before accords and preludes.....and I don't hear talk of one so it may not be possible or it's just too much $$$ for the average import enthusiast to afford unlike the $800-$1000 H2B H2D kits.Last edited by Kurobei; 05-29-2009, 05:31 PM.I need a custom turbo manifold built....
707 NorCal NinjaZ
koo yea anything is possible if you have the money so it probly can be done
as 4 the video i cant see it send me the linkhttp://www.cb7tuner.com/vbb/showthread.php?t=138029 <-mrt
Reverse H22 pictures...
The Apexi Drag integra uses a Xtrac transmission and I believe the Jaccs accord does too or something similar to this unit.
http://www.xtrac.com/pdfs/406%20Fron...ring%20Car.pdf
I'm scared to see a price on it...but yeah if u wanna go 6-speed here yah go until someone comes up with a adapter plate to mate a different 6-speed tranny to the F-block.I need a custom turbo manifold built....
707 NorCal NinjaZ
Originally posted by deevergote. View PostI'm shocked nobody has jumped on the idea presented above...
Since the K series spins the other way, like the F20C... A K series 6 speed could presumably be adapted to run the F20C in a FWD car. 6 speeds, and a 240hp 2.0L engine. Granted, you're looking at enough money to simply buy an S2000...
http://www.honda-tech.com/showthread...light=fwd+f20c
Thats an F20C wit an K tranny and a b series pressure plate or something like that.
