Your making nice progress. Looking good so far!
Alex13mod : 1992 Accord EX
Originally posted by JDMchristian991 View PostLooks like your moving right along. How do you like the rsx seats?
Update:
Here are some teasers until suspension is done:
After new bearing the new one decided to go hmm..claimed warranty
Thanks to EXCALIBUR all this is possible.
Had to order:
New Sway bar bushing only lasted like 6 months or less going poly filled bushing
Also ordered Poly Filled Trail Arm Bushing will be pressed in sometime this week once it arrives.
Final results are coming soon.
Originally posted by Raf99 View PostI'm curious what your ride height will be with the SS set to that height. I just purchased a set and I have them on the lowest they will go, but never installed them yet. can you take a pic when you are done the install of them?
To add to that will need Fenders rolled and wheel allignmentLast edited by Alex13mod; 05-25-2014, 11:03 AM.
Originally posted by Alex13mod View PostI will As soon as we get the bushing since we had to take the knuckle off to get the wheel hub pressed and as-well the Rear Trailing Arms to press the bushing.
Originally posted by Raf99 View Posti wish i could roll my rear fenders Had them fixed long ago and the shop used bondo ..... booo
Originally posted by Alex13mod View PostBondo is a NO NO and its a temp fix for rust repairs it will come back 10x worse if not repaired right with new Quarter Panels. I will post updates once I get my Hard Race Rear Trail Bushings and Poly-filled Sway Bar Bushings.
Well here are the updates as of
06/28/2014 Suspension overhaul complete
Before:
Had to replace wheel hub which had warranty
Needed OEM Upper control arms to fit the Ingalls Camber Kit
After 06/28/2014
Wheel Alignment still needed that will be on monday as-well as putting my Slipstream rotas :-)
