want to know if a stock manifold gasket on a f22a1 motor work with a DC Sport header.
header gasket.
Put the header on and if the gasket leaks change it. If no leaking I wouldn’t bother. Every time Iv done a header swap I NEVER changed the gasket all the gasket is 3 thin pices of metal pined together.R.I.P Rex 10/10/97-08/06/09
There aren’t enough words in this world to say how much you will be missed. love you buddy!
Reading this brings up a question that I often had... with header/manifold gaskets at the block and also where the "down: pipe connect to the header/manifold is it a good or bad thing to use high temp RTV? Personally, I use generous amounts of RTV when replacing gaskets, but the more I think about it, I dont know if that is the right thing to do?
My song of the week (or till I change it): Snow Patrol - Take Back The City
Originally posted by thewoahna View PostReading this brings up a question that I often had... with header/manifold gaskets at the block and also where the "down: pipe connect to the header/manifold is it a good or bad thing to use high temp RTV? Personally, I use generous amounts of RTV when replacing gaskets, but the more I think about it, I dont know if that is the right thing to do?
