I need help setting tdc on my f22a4, motor ok first off I took cam head intake and headers off already without sitting the tdcso how do I set the piston the cam and the timing belt really need some help with setting it thanks and all the parts are still off so all help will be put to the test
setting TDC help!
Hopefully you bought new gaskets to put it all together. I hope you also have a good torque wrench as well.
Since I'm listing necessary items, how about picking up a Chiltons or Haynes manual and thoroughly reading the engine rebuild chapter.
In both manuals it will outline how to put the motor at TDC.
As stated, get yourself a manual it shows exactly how to set correct timing. There is also somewhere here that has the information I think. Let me look for it.
Found it
Edit: http://www.cb7tuner.com/vbb/showthread.php?t=55332
