I looked for info on this and didn't see anything (everything seems to be H22 or H23 VTEC related), so apologies if I missed it.
Someone local is advertising a freshly rebuild 94 Prelude H23A1 using Honda parts, non-grindy M2S4 transmission, ECU, and harness for $490. That seems like a steal and a cheap way to freshen up my car, AND get an extra 20 ponies out of it.
I know the transmission needs a couple holes tapped and I assume I should use the Prelude ECU - correct? Any additional wiring I need to run? I already have the IABs since I have the EX. Will my power steering pump from my F22 work?
Thanks everyone!
EDIT: Forgot to add this motor is advertised with "high compression vtec prelude pistons".
Thanks everyone!
