I have a 92 Accord ex coupe. I am in process of thinking about how to clean my egr ports whether i should i remove intake manifold completely and install egr port plugs then or just tap and install with it still on car. I also have a question about what port plugs to use as far as material, brass or aluminum. Am assuming the aluminum is some alloy and wonder how closely it matches the OE IM. Brass is used now and i got to think that is for a good reason like brass can handle the constant expansions for long times and maybe aluminum doesn't. WHo kows the real reason why right. These are screwed in port plugs though and not caps. I still got to think brass is better. What do yall think? Also do you it is worth it to remove the whole IM.
EGR Ports
Can all that carbon in the ports be cleaned well while IM is still on car? That is really my other question. It is probably just the first couple that are clogged. I guess once i open it up i'll know how bad it really is. What is the best way also once i open up those plugs to clean it. Spray a bunch of carb cleaner in there and let it sit for a few hours?
There are some DIYs on this that have pictures that show you how to do it. It's not hard to do. Just go to the DIY section under engine and search EGR~Nick~
Originally posted by F22Chris View PostI used a rifle brush
Originally posted by F22Chris View PostFigure out the thread/pitch for the plugs and get the matching tap set for them. No - it doesn't matter for aluminum, if anything it'll be easier because the metal is a little soft capared to a high carbon steel/iron.Last edited by zedjr10; 04-12-2017, 11:15 PM.
