lets see how low your cb7 can go...
    this is mine not that low but looking to go lower so looking for the right look
    /thread
      ^Thats not that low. He just hung a big body kit off it to reduce clearance. And those are like 19s with rubber bands and they aren't that hard to tuck.
      I'm not the lowest on here, but thats tucking 2" on a 175/60/14.
      I got new tires for this summer that should put me lower. Stay tuned next week for meet pictures.
        Let me guess, and that suspension was stock too???
        If you say so...
          So I was thinking what would Jesus drive?
            [QUOTE=whiteboyjune69;2793781]this is mine not that low but looking to go lower so looking for the right look
            did you buy your corners or did you paint them?
              if you want max drop then you don't need struts or springs
              just remove them and it will sit almost on the ground.
                this is my brothers wagon "trurider69"
                ''COUPE''
                ''WAGON''
                  They look painted to me. Sometimes when u paint them they come out all milky looking like that. The ones u buy are usually pretty nice and clear.
                    91 ex coupe-daily
                    91 2.0si (cb6)original RHD-project
                    R.I.P sedan.... will be missed
                      static drop tucking 1.5" of tire on 205/45/16's with 4*s of camber all around.
                      about 1" of ground clearance from the frame rails.
                      Customlowz was on bags so that shouldn't count. thats like being a superhero in the olympics. its obvious your gonna win so you can play.
                      if you haven't had to notch your strut towers to fit the UCA's, or swapped to EF UCA's, your not that low.
                        plus 1 for the CONNECTICUT CREW!!!
                        hey are u the one that race jaber in the green/blue ish accord and lost today....?
                        205 55 r15 tires back when i had agx shocks and coil overs
                        now same tires on race springs and knoi yelloows lowest perch
                        my new turbo build
                          Research this car. It had air suspension.
                          If you say so...
                          Henry R
                          Koni/Neuspeed
                          1992 Accord LX R.I.P
                          1993 Accord EX OG since 'o3
                          Legend FSM
                            check this out
                            92 cb7 http://www.cb7tuner.com/vbb/showthread.php?t=176886
                            91 cb9 wagon
                              holy giant lip....
                              sweet foglights though.
