First off my car is a 1992 Honda Accord it originally had an F 22 single overhead cam motor and an automatic transmission after blowing multiple head gaskets I ended up with a 1996 H23a1 5spd combo out of a prelude. My question is although I have all the dash and main engine harness out of the prelude I don't have the time to do the wiring swap can I put my F22 intake and main engine harness on to the H23 motor so it all plugs into my factory car wiring harness and also will the F22 ECU start and run the H23 motor if not and I absolutely have to change the wiring harness' Will my gauges in my dash plug into the prelude wiring harness and work properly or will I have to do custom wiring job for that. Any help given will be greatly appreciated thank you have a nice day
Will
Will
