I've seen something vaguely similar where someone bolted two throttle bodies directly on to the lower plenum but this looks like a much cleaner, more professional setup. The stacks would definitely look cool too. Instead of hiding behind the motor facing the firewall, they'd be pointed upwards and in pain view.
Machine Shop Project
My buddy made this plate. To block off th sqaure holes. There will b another iab plate on the bottom. Plate was mmade because there will b 2 much vaccum.
The 2nd plate will have drilled out holes for vac lines and for the brake booster.
Any input will b great. Thanks.**Blk Housed Slut Crew Member #1**
Looking great.... very Good idea.... how thick is that plate? Not that it has to be thick, I'm just wondering.
You will ether want to make 2 soft seal gaskets out of a roll of flepro gasket maker or you could opt for the messier option of using RTV gasket maker..... I have alwyas used a 3/32" roll of Felpro gasket material to make all of my intake manifold gaskets, they haven't failed me yet. You just have to make sure you get good even clamping force and that they surfaces are true.
He replied
Idk how thick but its more of a shim than a plate I guess.**Blk Housed Slut Crew Member #1**
For those of you who are interested in my friends project.. the machine came back with a block plate for the square ports. Remember he's doin itbs using iab plate... he said any info would b great.
I think it looks fukin sweet. He wants to try it on my f20a... but I don't think he will get it back**Blk Housed Slut Crew Member #1**
Originally posted by '93CB7Ex View Posthow are you gonna run a tp sensor? iac? air filter?
Friend said...Small air box will mount on top,and I already have plans on hooking up iac. and tps is hooked up in previous posts.
Thanks**Blk Housed Slut Crew Member #1**
