Originally posted by evil_demon_01
View Post
Overheating and fan won't stop running!
i say check your fan relay. and also check if the radiator jacket is leaking. what i did was after wiping around the top (while it was still cold). took it for a spin around the block but with a heavy foot lol. after that, pulled the bonnet and check around the the jacket to see if there is fresh coolant residue on it at the top. that means u need a new radiator. also check your head gasket for idle issue if its not the IACV. probably blown hopefully u didnt hit bearings. good luck'91 Concord Metallic Blue. Status: under construction
Originally posted by JDMDriver View PostI disagree as I once made a mistake of not reconnecting the electric fans after removing a radiator and the car overheated. The car had boiling water trying to come out of the reservoir (since it has a screw top lid) but it didnt mean the cars head was blown.
Water trying to make its way to the reservoir in my opinion is due to the overheating (not necessary a head gasket problem). A head gasket problem can lead to overheating but overheating is not necessarily a head gasket problem.
1. Inspect for coolant leaks (around hoses, block, under the car, timing cover/water pump)
2. Check Coolant Level
3. Inspect/replace the radiator cap
4. Check for proper thermostat operation
5. Check for proper fan operation (that they work & sucking air through the radiator / blowing air onto the header/heatshield)
If everything checks out, and appears to be working properly, sorry buddy its most likely a headgasket. This is one of the many ways a headgasket can fail / or problems it can cause. Coolant in Oil, or Oil in coolant is another sign. Excessive moisture/vapor coming from the exhaust after the vehicle is sufficiently warmed up (10-20+ minutes depending upon ambient temperature)
As for where to get a headgasket set, I would personally see about aquiring a Stone/Ishino headgasket set. Ishino is the company Honda uses for its headgaskets, Ishino translated into english is Stone. Ishino = Stone. Stone = Inexpensive compared Ishino from Honda = Arm & Leg
Ok ok ok.....
I figures everything out. My head gasket is fine. The previous owner didn't use antifreeze but just used water. It froze, hence the disappearing coolant and overheating. I melt all of it, via my gf's hairdryer(sshhhhhhh!) and drained it out. I replaced with antifreeze and let the air bubbles out. It runs perfect now. Oh and I tightened the valve down and it doesn't idle funny anymore.
Seriously, thank you for all your help. You have no idea how much I needed it.
Take care!
