#1 |
![]() Completely "Refurbished" Head (New Exhaust Valve Guides, Retainers, Bisimoto Pro Race Springs, Valve-Job, etc), ARP Studs, Ishino/Stone Headgasket
*Completed: 7/10/2009 CHR p&p doublestack hybrid intake, bisi intake gasket, unorthodox pulleys, & a6 cam/oil cooler/windage tray/pt6 upgrade, oem stanley fogs, polished valve cover *Completed: 4/18/2009* Pictures on pages: 1, 2, 3, 4, 5, 6, 7 ![]() Mod List: Fluids: -Royal Purple Synthetic 10w30 Motor Oil - Last Changed @ 187k 4/2009 Flushed: 180k Changed: 187k -Honda Genuine ATF @ 180k 4/2009 Flushed: 155k Drain & Fill: 180k -Penzoil ALL Make/Model Coolant Flushed: 180k w/ Purple Ice (up to 20% cooler) @ 180k 4/2008 -87 octane unleaded Fuel Injectors Cleaned: 155k Fuel System Cleaner: 172k Fuel Filter Replaced: 178k 4/1/2009 Engine Info: -f22a1 block *stock* -All new Honda Oil Gaskets and Seals @ 180k 4/18/2009 -Ishino/Stone Headgasket @ 184k 7/2009 -Completely "Refurbished" Head @ 184k 7/2009 -Bisimoto Pro Springs @ 184k 7/2009 -Polished Valve Cover @ 180k 4/18/2009 -a6 oil cooler @ 180k 4/18/2009 -a6 windage tray @ 180k 4/18/2009 -a6 cam @ 180k 4/18/2009 -CHRRacing P&P a6 lower intake runners @ 180k 4/18/2009 -CHRRacing P&P h23 upper intake plenum @ 180k 4/18/2009 -H23 60mm Throttle Body @180k 4/18/2009 -New FITV @ 180k 4/18/2009 -pt6 ecu @ 180k 4/18/2009 -Resoldered PGFI Relay @ 138k -Aluminum Radiator & New Hoses @ 140k 2/2008 -Denso O2 Sensor @ 179k 4/2009 -K&N Air Filter @ 174k 1/2009 -K&N Oil Filter @ 174k 1/2009 -JDM Mugen Radiator Cap @ 145k 2/2008 -JDM Mugen Oil Filler Cap @ 145k 2/2008 -JDM Mugen Thermostat @ 177k 3/2009 -JDM Mugen Fan Switch @ 177k 3/2009 -Unorthodox Ultra Sc Crank Pulley (Stock Diameter) @ 180k 4/18/2009 -Unorthodox Ultra A P/S Pulley @ 180k 4/18/2009 -NGK Laser Platinum Plugs @ 150k -NGK 8mm Plug Wires @ 179k 4/05/2009 -All New Air Conditioning except piping. @ 157k 5/2008 -All New Valve Cover & Spark Plug Oil Seals @ 157k 5/2008 -Interstate Battery @ 165k 8/2008 -Alternator @ 170k 11/2008 Exhaust: -Stock A1 Exhaust System Suspension: -Four Wheel Independant Suspension *stock* Alignment @ 174.5k Drivetrain: -4 speed automatic transmission w/sport mode *stock* Traction/Wheels: -15" Enkei 16 Spoke Honda Motor Co., Ltd Alloy Rims from 86-88 Acura Legend @ 150k -Federal P195/60R15 @150k -New PS Front Disc @ 143k -DS Resurfaced @ 143k -New Front Brake Pads @ 143k Exterior: -Performance Trends Blackhoused Projector One-Piece Headlights @ 125k -15% Window Tint Applied Sides & Rear @ 142k 4/2008 -Blackhoused Bumper Turn Signal Lamps @ 171k 12/2008 -EuroLite 1156 Amber Bumper Turn Signals @ 172k 12/2008 -DIY Gutter-guard Painted Grill @ 171k 12/2008 -92 Ex Front Valance *stock lip* @ 177k 3/2009 -OEM Stanley Fog Lights, Harness, & Switch @ 180k 4/18/2009 Interior -Gray Cloth Interior *stock* -Sunpro Universal Single Gauge Piller @ 179k 4/2009 -Autometer Oil Temp Gauge @ 179k 4/2009 -Autometer Autogauge Oil Press/Volt/Coolant Temp Gauge @ 179k 4/2009 Electronics/Misc: -JVC DV5300 DVD/MP3 DIN 10/2007 -Alpine V12 45w RMS x 4 @ 4ohm 5/2008 -4x Infinity Reference 6.5" (Shallow Mount for Doors) 10/2007 -Alpine V12 300w RMS @ 4ohm 500w RMS x 2ohm 5/2008 -1x 12" JL Audio 12w1 @ 4ohm (Custom Sealed Box) 5/2008 -Audiovox Prestige Alarm 10/2007 -Rust Evader System *came with car -150W Power Inverter Future Plans: -- Engine -- Balanced & Blueprinted Rebuilt F22A Shortblock Golden Eagle 86mm Sleeves Bisimoto 12:1 Forged Pistons w/Moly Coated Skirts Bisimoto Forged H Beam Rods OEM Honda Bearings ESP Traction Bar w/ Front Torque Mount ESP Poly Motor Mounts AEM Cold Air Intake w/ Bypass Valve Bisimoto Cam Gear Bisimoto Stage 2.5 Camshaft Regrind -- Exhaust -- Bisimoto Stainless Steel Ceramic Coated Header *Purchased* Venturi 2.5" in / 3.0" out Magnaflow Spun Catalytic Converter 3.0" in/out Venturi 3.0" in / 2.5" out 14" & 22" Resonators 2.5" in/out Quiet High Performance Muffler 2.5" in/out -- Suspension -- Koni Yellow Neuspeed Edition Struts & Race Springs 2.25" drop. -- Drivetrain -- H23 Manual Transmission Quaife LSD -- Traction/Wheels -- 17" Konig Unknown's Toyo Proxes T1-R 215/40/17 -- Exterior -- Rainguards -- Electronics/Misc -- Hondata S300 Chipped P72 Equivalent Laptop Mount Stand Multi-Battery Isolator Custom Dual 12" Sealed Box Second JL Audio 12w1 Current Dyno Sheet: 110whp @ 6k / 108wtq @ 4.5k ![]() Exterior Photos: After fogs: ![]() ![]() Before Fogs: ![]() ![]() Photos taken in Seattle, Washington (A year ago before lip, grill, fogs, blackhoused turn signals): ![]() ![]() ![]() ![]() ![]() Interior Photos: ![]() ![]() Engine Compartment Photos: Before: ![]() Currently: ![]() This is a video of park/neutral revving, so you can hear the intake: Here is a 0-90 pull video: Here is the Dyno Video:
PT3/6 Development Thread | My 1991 LX Coupe | DIY: 90-93 Tcu Fix | FPV Pilot's Blog Last edited by cloudasc; 03-11-2010 at 12:51 PM. Reason: Mod List Updated* |
#2 |
Boost Junkie Rehab!
how those
hey bud remember me!
free wheels at the SI meet! anyways rıdes lookın good tıme for a lıl change tho what you got next ın mınd? |
#3 |
great start........
![]() ![]() better than I am when I got my cb...
![]() ...........AE86-GTS: SOLD.................................................. ........CB7-DX: SOLD |
#4 | ||
![]() Really old photos (3/2007)
The car was completely stock until somone put me in their blind spot then tried to merge into me while its wet outside, and this is what the outcome was: ![]() ![]() ![]() This is when and why I replaced my headlights ![]() ![]() Insurance Totalled out my car for 3.2k and I got to keep salvage valued at $700, repairs & paint were only $2200, I used the extra money to purchase a new deck & have an alarm installed. Here are the shop pictures: ![]() ![]() ![]() ![]() ![]() The day it got out of the shop: ![]() ![]() Quote:
PT3/6 Development Thread | My 1991 LX Coupe | DIY: 90-93 Tcu Fix | FPV Pilot's Blog Last edited by cloudasc; 01-18-2009 at 02:25 PM. Reason: Inserted Pictures of the Past |
#5 | |
nothing wrong with it.....I myself own older cars too... ![]() ![]()
#6 | |
Oh and I got new rims, they are from a 86-88 Acura Legend, picked up the set for $100. Got new and had them installed, here are the pics: 4/15/08 ![]() ![]() ![]() ![]() ![]() ![]() ![]()
PT3/6 Development Thread | My 1991 LX Coupe | DIY: 90-93 Tcu Fix | FPV Pilot's Blog Last edited by cloudasc; 02-01-2009 at 02:13 AM. |
#7 | |
great deal for car with little to no rust.... I got mine in 06 with no rust and around 96xxx miles...for around the same price... ![]() ![]() ![]()
#8 |
Woo Hoo, just got my car Tinted! Now I gotta wait 3 days to roll down my windows, but thankfully i drive a coupe and have the rear pop outs, plus my ac works =P
PT3/6 Development Thread | My 1991 LX Coupe | DIY: 90-93 Tcu Fix | FPV Pilot's Blog |
#9 |
tint look good..........
![]() ![]() how much tint was it?
#10 |
The tint was 261.25 after tax, i gave them a tip, that rounded it off to 275, oh and its 15%
#11 |
Accord of the Month: August 2008
Nice looking coupe..
accordtypeR aka Seve aka The Godfather. ![]() My Old Baby....................My New Baby SOLD TO..grumpy93, iceplaya123, slr_theking, tn_accords |
#12 | |
#13 | |
where? body shop? ![]()
#14 |
#15 | |
#16 |
not bad at all, dump it
![]() im pissin on the game feel like i got a weak blatter |
#17 |
still have no idea.... I love to do it myself but i figure it best for pro... ![]() ![]()
#18 | |||
![]() Quote:
![]() ![]() ![]() ![]() Quote:
#19 | |
too bad its not here......... ![]()
#20 | |
looking good.......... ![]() ![]() I just don't like the headlight....... ![]() ![]() Plan to get a different set?
Thread Tools | |
