Old 06-09-2011, 07:14 PM   #1
Boredumb
Newcomer
Boredumb is cool... so far.
EGR Hose not connected
I just failed emissions and went to check my O2 sensor and EGR, the O2 seems to be fine. Then I was going to clean my EGR, but before I disconnected it, I noticed the hose is not there, I think this might be the cause of my problem. This is on an H22A if that matters.
My question is where am I supposed to connect this to? The part coming out on the right side is what I'm talking about.
Also my idle is low and the car does die after hard acceleration so it definately seems like this should be the issue, however if this does not bring my idle up enough, if someone could show me which screw I turn on the throttle body to adjust the idle I'd appreciate that.
Thanks in advance for your help.
Boredumb is offline   Reply With Quote
Old 06-09-2011, 07:32 PM   #2
559cb7559
Newcomer
559cb7559 is cool... so far.
yeah disconnected egr would cause it to fail smog
559cb7559 is offline   Reply With Quote
Old 06-09-2011, 07:46 PM   #3
Boredumb
Newcomer
Thanks. I assumed as much. Just figured out how to adjust the idle on the throttle body. Still need to know where that hose is supposed to connect to.
Old 06-09-2011, 07:51 PM   #4
djcaz_aom
Contributing Member
djcaz_aom seems to have made some friends! djcaz_aom seems to have made some friends!
It goes to the black box on the firewall.
It is hose #16. It goes to the EGR control solenoid.
djcaz_aom is offline   Reply With Quote
Old 06-10-2011, 04:16 PM   #5
Boredumb
Newcomer
I think my egr solenoid might be missing altogether. Could someone take a pic of theirs so I can see exactly what I should be looking for?.
Old 06-10-2011, 06:19 PM   #6
madmattr6
Newcomer
madmattr6 is cool... so far.
Its a rubber hose that your missing...it either connects to the vacuum box or the manifold..that missing hose can cause ur engine to die since you have a vacuum leak..im guessing you failed the smog test either because you had a check engine light or high nox....right?
madmattr6 is offline   Reply With Quote
Old 06-10-2011, 07:20 PM   #7
Boredumb
Newcomer
Quote:
No check engine light. It was High Carbon Monoxide that caused me to fail.
When you say it either connects to the vacuum box or the manifold, do you mean it can connect to wherever?
Old 06-10-2011, 08:08 PM   #8
coupes
CB7tuner Member
coupes is cool... so far.
Nope..... the black box on the firewall above the charcoal canister should have 3 hoses coming out the bottom..... the one marked 16 should go to the egr although in may be too short to reach the prelude egr......
coupes is offline   Reply With Quote
Old 06-10-2011, 08:54 PM   #9
Boredumb
Newcomer
Quote:
I think I might be missing this box? Do you know a part number for it?
Old 06-10-2011, 09:09 PM   #10
coupes
CB7tuner Member
I can get you a part number but you're better off going to the jy for that....... it's on the passenger side on the firewall
Old 06-10-2011, 09:15 PM   #11
Boredumb
Newcomer
Alright yea. I'm missing that whole thing. Thanks a lot for the picture. I'll check some junkyards this weekend.
