So someone stole my radio out of my cb7 a few weeks ago, i went to start the car to go smog it but when i went to crank the car there was a loud buzzing sound coming from behind the glove box, the buzzing slowly went down and when i went to crank the car again it was completely dead. I jump started the car and parked it and noticed the dash lights and rear drls stay on. I disconnected the dimmer relay thinking it was that but the lights still stayed on. Any ideas where to start? I have a DMM, just dont know where to even start.
91 accord daytime running lights stay on with key out
Any tips on which wires to check or if you have a schematic i could follow? I just want to get these drls fixed so i can move onto doing the rack and pinion and power steering pump
Originally posted by h22sparkle View PostProlly a power ignition wire prolly the same one that's ran off the headlight and headlightswitch and cigarette lighter switch. Just electrically tape it up and make sure all the wires are covered. Damn dude cover her up tight.
Anyone know how to test the headlight/combination switch, i feel like maybe this is where the issue is coming from, just have no idea how to check it with my multimeter. Im really hoping to get this issue resolved soon and not have to jerry rig the dash and brake lights.
Any advice or insight would greatly be appreciated
First piece of advice - go buy a manual. If you are going to deal with this wire mess and later a rack and pinion you will need a manual. You will pull your hair out with out one wondering if that wire beside the blue wire is white and pink or white and purple.
Next, check all the fuses that are related to your problem. In fact, i would pull the radio fuse right now. It sounds like wires are still touching somewhere so sort that out first.
Already capped all the wires, rack and pinion wont be an issue, ive done it before on a different cb7. Ill pull the radio fuse when i get access to the car later tonight. But does no one have any idea where to start? I have a multimeter and can check all the wires just not sure which wires go where. I figure if the dash lights and rear drls are staying on then something with the headlight/combination switch has to be the issue here or am i wayy off on that assumptions? Honestly at this point im just gonna try to get my post counts up so i can post in a more technical forum. Because i dont want to be dealing with connecting and reconnecting the battery everytime i drive
And i already checked all the fuses under the hood with a multimeter and all fuses checked out ok. The issues is a short somewhere between the radio and headlight/combo switch i believe
Originally posted by Raf99 View PostFirst piece of advice - go buy a manual. If you are going to deal with this wire mess and later a rack and pinion you will need a manual. You will pull your hair out with out one wondering if that wire beside the blue wire is white and pink or white and purple.
Next, check all the fuses that are related to your problem. In fact, i would pull the radio fuse right now. It sounds like wires are still touching somewhere so sort that out first.Last edited by Dabsfordaze; 01-11-2017, 06:07 PM.
The backlight for the dash stays on( so the speedo, tach, temperature and fuel gauge are Illuminated), hvac controls Illuminate. And tail lights stay on. Not the brake lights. If i leave the door open it chimes as if the key were in the ignition. Headlights work when i twist the headlight switch. Turn signals work. But when i go to turn off the all lights the dash, hvac controls and rear drls stay on. I dont believe i have canadian DRLs, but ill check when i get home. Dome light i has set to always off so im not sure if that stays on or not.
Originally posted by Raf99 View PostSooo give me more info.
- Do your headlights stay on? / does the car have Canadian DRLs?
- Does your fuel gauge stay on?
- What lights specifically are on....? (instrument cluster all, center dash console lights all (radio, heater, etc.) and dome light? )
Noob question but how would i know if i have canadian DRLs? Im in California so highly doubt that i have them but you never know, a previous owner could have installed them.
Sidemarkers illuminate, brake lights illuminate, licence plate lights come on. Like if you turned your headlight switch over 1 click before turning on your headlights. Brake lights work normally as do reverse lights. And headlights turn on when you turn the switch to the last position
Originally posted by Raf99 View PostUmm you probably do not then. DRLs = high beams work at 25% when driving down the road with your lights off. If not, explain what you are referring to for rear DRLs.
