f22a4 fuel system..NEED HELP
    I had my fuel pump go out so I replaced it with a 255lph fuel pump and it works fine but when I get to a stop and start to go again it chokes and cuts out and then dies...what could be my issue ? im open to all ideas if i havnt tryed it .
    I think you have to bleed the system...
    If not some junk is probably stuck in your fuel filter
    MRT
    sneaky motherfucker
      you may be right on bleeding it but i just changed the filter and its still trying to cut out im not sure if it is too much fuel for the rail or injectors or what it could be off hand this minute
