Before:
After:
Completely Stock, except for:
K & N drop in air filter
Steering Wheel Cover
Radio and speakers
Fog lights
Led license plate
Yakima roof rack with Bowdown and Frontloader attachments
Complete Prothane
Yellow caps
Dome light thing w/ homelink
Repaired:
All 4 pads (Duralast)
New back right caliper
Front rotors
4 new wheels
Timing belt and balance shaft belt
Front shocks and the tubes inside of them (Monroe Quick struts)
Front Upper and lower ball joints
Valve Cover gasket and oil pan gasket.
New Muffler
Rad cap
Replaced right front turn signal
JB welded the other one
Fuel filter
Purged Brake lines and bled them
Master Cylinder
All 4 ABS sensors
ABS Pump motor
PCV Valve
Repainted the roof (Needs it again)
Interior passenger door handle
Rear passenger window (Fuse!)
Inner distributor seal
New Spark plugs, 3-16-11 128k
New Spark plug Seals,
Valve adjustment
Painted Valve Cover
Drivers side wheel bearing, 4-12-11 130k
Had the passenger side one done, idk the miles
Changed trans fluid every spring
Fixed some rust (drivers side quarter panel)
Future Plans:
Fix the rust and paint it in the spring
Coolant leak
Drivers side vanity mirror light
Distant Future:
Custom Traction Control
Turbo Charger Jet plows
Headlights that make HID's look dark (Maybe)
Manual when my Auto Breaks
A1 to A6 upgrade. (Most likely just going to do H23 intake)
More (Better) pics on page 3, 4, and here
