What is your MPG?
    What is your MPG?
    I thought i would start a thread to see and compare gas mileage..also you may want to include engine mods and other variables that would factor into your results.
    My gas mileage as of right now is 22mpg
    Originally posted by 93accordexcoupe
    cleanest oem rims ive ever seen
    Members Ride
    around 25 on crusing. and like 10 on wot.
    miss my turbo cb7
    moved onto volvos. dont know how that happened, just did
      I average 28 or so.
        23, automatic.
          27 auto
          REPPIN' THE DIRTY
          650
          http://www.cb7tuner.com/vbb/showthre...27#post1570627
            19-23 city
            26-32 highway
            automatic
            BTW, 22 isnt SO BAD, according to the gov. our cars are rated for 22-24 combined now with ethanol gas
            90 accord EX automatic F22A4 232,500
            DIY ram intake
            0gauge/4gauge BIG 3
            stock alt rewound to 120amps
            optima orange top 830cca 1030ca
            fully synthetic valvoline "Max Life" 5w30
            Other rides:
            2004 Jeep Liberty v6
            2001 Honda civic ex coupe 1.7 vtec
              i'm always amazed when i see ppl getting over 26 mpg, how are you guys calculating your mpg?
              I set my trip meter when i fill up and when the gas light comes on divide the number of gallons it takes to fill up my tank by the miles I drove on the previous.
                my gas light never worked and it doesnt work in my prelude either
                when my needle hits the last mark is when i look at my trip-o
                im usually at 350-400 and if its all interstate
                then i get 425-450 miles on the trip o meter.
                i kno im either running rich or lean and i think i have an exhaust leak.
                Stock F22A6 w/ OEM tuneup ( wires cap plugs ) SRI no name filter or intake direct air intake scoop. clean motor well maintained. A/C and A/T FTL ( but im thankful for it sometimes. )
                [COLOR="Magenta"]
                  i get about 22 to 23 mpg
                  Click Here To Check Out My Ride
                  http://www.cb7tuner.com/vbb/showthread.php?t=137030
                    26-28 with my f22 auto, city and highway combined, using A/C occasionally.
                    H22 Fund Cancelled. Flight training underway.
                      25-26 city, 31 hwy. H22 5spd LSD tranny. Stock F22 intake/exhaust.
                      Thats how I measure also Wilson. But I drive slow on the freeway, and I don't do jack-rabbit take offs
                      My swap thread
                      Main relay proplems?--DIY
                        Phantom... PLEASE resize your sig.
                        The MAX is 800x300.
                          28, auto, f22a6, rotted muffler, cut open airbox
                          you'll love my nuts!
                            Im getting 25 with an auto f22a6, Short ram. Changed o2 sensor 2000 mi ago. plugs/wires/pcv 500 mi's That was with some heavy footed times though... It could (and will...) be better. To find mine I waited untill the gauge was just above the red, put 4 gallons in it, and reset the odometer.
                            It was at about 104 mi by the time it got back to the same spot. 100/4= 25
                              About 28, mostly 50-60mph. I worked it out by figuring out how much gas I go through getting to and from work every week - I don't often go elsewhere.
