Go Back   CB7Tuner Forums > Site Features > DIY's
Old 08-13-2006, 03:54 PM   #1
4CYLPOWER92
4CYLPOWER92 is cool... so far.
ENG: MAIN RELAY REMOVAL AND REPAIR (pics)
I finally decided it was time to fix my annoying main relay. After reading countless threads on this forum and others, I've noticed that pictures and detailed instructions are impossible to find. Vague drawings in repair manuals are all I've seen for the most part.
Here we go!
You need a socket wrench with an extention or 2, a size 10mm socket, and some patients. You might even want to do some yoga before attempting this. The location of the main relay in our cars is the main reason this job is hard.
Put your upper body including your head, down on the floor board where your feet normally go. Now look up left of the stearing columb, above and left of the fuse box. You won't be able to see the main relay yet. The cruise control box is in the way.
So there are 2 10mm bolts holding the CC box in place. Remove those and slide the box out of the way.
Here is the CC Box dropped down by the foot rest.
Now you should be able to see the main relay.
Now don't bother unconnecting the connector yet. It is a tight space to work in, and the connector is tight. There is one 10mm bolt holding the main relay case to the car body. Take that bolt off. Now, you might be able to remove the relay at this point, but maybe not. There is a black plastic box painfully close to the main relay, and the metal relay bracket is undernieth that plastic box bracket. Take off the other 10mm bolt to that bracket in order to loosen it up. Now with a few wiggles, the main relay box comes right out. Now you can unconnect the conector, with the help of a screwdriver for a little prying.
Here is the culprit:
The problem that causes us all pain. These are the 2 locations that looked obviously cracked to me. There could be others that are hard to see visibly, so I went ahead and resoldered every single connection.
Now I'm not an experienced person at soldering, in fact, I've only attempted it once or twice before. It's not that hard. I got a 30amp solderer from Radio Shack, and the thinest wire they had.
I've read somewhere before, that after soldering, you should drill some holes in the main relay holder box. Not sure of the purpose of this, maybe it keeps the relay cooler. Can't hurt, so I did it. I used some sharp surgery scissors to put 4 holes through the casing, since I have no drill.
Installation is the reverse of removal. It wasn't that difficult, really.
Then pray you didn't damage the relay, and start the car
Mine started right up. Now only time will tell how the resoldered joints hold up. I'm keeping my fingers crossed.
4CYLPOWER92 is online now   Reply With Quote
Old 08-13-2006, 04:05 PM   #2
blackcb7
Accord of the Month: May 2008
blackcb7 is cool... so far.
wow nice write up kane, i'm sure this will help a lot of people out
Members Ride
blackcb7 is offline   Reply With Quote
Old 08-13-2006, 04:13 PM   #3
4CYLPOWER92
I hope so. I just had to share my pain
Old 08-13-2006, 04:58 PM   #4
aleks77
aleks77 is cool... so far.
just wondering you solder right on the green thing right? wat happens if you solder 2 of those soldering points together? im just not exactly sure what to solder?
1991 Accord LX Coupe - F22 SOHC 357whp @ 19 psi on pump
Member's Ride Page
Northwest March 11th '06, CB7 Meet Video
Vouches: | Bisimoto | cp[mike] | Datmofo | RENR | TypeG | 93accord | T3h HoT!! | fst4dr91 | suprachica79 |
aleks77 is offline   Reply With Quote
Old 08-13-2006, 06:01 PM   #5
4CYLPOWER92
Yeah, you solder those round silver things that are already soldered from the factory. If you solder 2 of them together, you are screwed. But there are tools for removing solder.
Old 08-13-2006, 11:02 PM   #6
deckeda
deckeda is cool... so far.
Nice DIY. Anybody know if someone other than Mitsuba makes a compatible relay? Just wondering if the design was ever fixed/bettered over the years. I take it there wasn't ever a TSB for this ...
deckeda is offline   Reply With Quote
Old 08-13-2006, 11:45 PM   #7
TypeG
Moderator
TypeG seems to have made some friends!
if you take this plastic cover off, it's a lot easier. once you take off the plastic cover, there're 4 10mm bolts holding a metal brace on. remove those bolts and you should be able to see the main relay.
later.
Avoiding dirt at all costs
Atlanta Meet/Mountain Run April 10th-11th 2010
TypeG is offline   Reply With Quote
Old 08-13-2006, 11:51 PM   #8
laz
laz is cool... so far.
Send a message via AIM to laz
That reminds me of the day I had to take mine out to get fixed.
You should do all points since it is already out, and it is not hard at all.
The relay is a good design, it is just that the cars las too long!
You remove the cover, but you still have to go at it from underneath, and the position is the sux on your back.
laz is offline   Reply With Quote
Old 08-14-2006, 04:26 PM   #9
91hybridaccord
Location: Tucson, Arizona, THE CITY OF BROTHERLY CAR THEFT
91hybridaccord is cool... so far.
Tried this yesterday on two bad relays, and they both work flawlessly now.....great write up......sure beats paying $70+ from the dealer new
1991 Honda Accord Ex
Pics of the beast!
::::198.4 WHP and 146.6 WTQ Currently weighing in at 2700lbs...best time: 14.8@92mph::::
2003 BMW 330I Sport.....Daily Hustler....
Road Race #1
Totoro Squad #2
91hybridaccord is offline   Reply With Quote
Old 08-14-2006, 06:33 PM   #10
Stealthman80
Stealthman80 is cool... so far.
that piece is 70$ WTF????
My Members Ride Page
Stealthman80 is offline   Reply With Quote
Old 08-14-2006, 11:37 PM   #11
doylna
doylna is cool... so far.
I bought mine new on eBay for $35 shipped about 2 years ago...always an option I guess.
doylna is offline   Reply With Quote
Old 08-15-2006, 02:03 AM   #12
TypeG
Moderator
i don't know where you guys get your parts, but i bought mine from the honda dealership for $45. later.
Old 08-15-2006, 02:35 AM   #13
accordaffair
accordaffair is cool... so far.
Send a message via ICQ to accordaffair Send a message via AIM to accordaffair
I did this the other day...hehe you have the same radio shack iron and solder I got! I got a desoldering iron while I was there too, works good once you get the hang of it.
bummer for me is, I fixed the relay and turns out nothing was wrong with it, so I wasted a whole bunch of time but I'm sure it will come in handy down the road somewhere
accordaffair is offline   Reply With Quote
Old 08-15-2006, 01:36 PM   #14
timmy0tool
Accord of the Month: April 2006
timmy0tool is cool... so far.
Send a message via AIM to timmy0tool
thanks for this! the pics should help myself as well as others. i need to do this as well. i never thought about resoldering the connections before so thanks for saving me a few bucks and a trip to the dealership.
- 92 LX coupe
- 96 EX wagon
timmy0tool is offline   Reply With Quote
Old 08-18-2006, 12:24 AM   #15
4CYLPOWER92
Yep, I wouldn't expect an Electrical Engineer to go buy one of these!! LOL.
Old 08-18-2006, 12:43 AM   #16
blazenem
blazenem is cool... so far.
Send a message via AIM to blazenem Send a message via Yahoo to blazenem
yeah mine didnt cost that much either dont remember exactly but i know it didnt cost 90 cuz i wouldnt have gotten it.. but i need to take the old one out it too damn hot out here in az to be up under a dashboard i just needed to use the car so i just unplugged the old one and left the new one danglin when i get it out maybe ill resolder it and sell it for 10 or 15 bux lol
Turbo f22 coming soon
Ride List
1988 Mitubishi Starion - newest project(on hold)
2005 Mazda 6s - daily driver http://www.cardomain.com/ride/3171724
blazenem is offline   Reply With Quote
Old 08-18-2006, 01:59 AM   #17
aleks77
fixed mine yesterday, cant really tell which are cracked tho, but the car fired up and hasnt given up yet, will let you know if it fails, and if it doesnt in a month ill also let u guys know! Mine used to crap out 3/4 times a day!
Member's Ride Page
Old 09-01-2006, 04:18 AM   #18
WilliamW
WilliamW is cool... so far.
Send a message via AIM to WilliamW
Great write up. I had to find and remove the relay tommrow and this is just what I needed. Took like 2 min searching. Thanks!!!
My Ride.
Originally Posted by WilliamW View Post
I feel like I'm doing a motor swap with my feet.
WilliamW is online now   Reply With Quote
Old 09-01-2006, 05:06 AM   #19
Ralphie
Stalker
Ralphie seems to have made some friends!
Send a message via AIM to Ralphie
Yea good write up. That last picture looks like you were ready for surgery lol. This will deff come in handy.
Ralphie is offline   Reply With Quote
Old 09-01-2006, 05:10 PM   #20
sunburn
sunburn is cool... so far.
Send a message via AIM to sunburn Send a message via Yahoo to sunburn
nice diy i used it today, i replaced mine with a new one (oem model) and amd going going to repair the old one).thanks
WE MISS YOU JO(9-04-2008)
sunburn is online now   Reply With Quote
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
