Replacing alternator need guide or video with pictures if possible. I am stuck on how to loosen the timing belt.
replacing alternator 91 accord
It's not the timing belt.
Make sure you take the negative off the battery.
There are two small adjustment bolts at the front of the alternator. (8 or 10 mm)
The long bolt that goes side to side needs to be loosened and removed.MRT
Originally posted by Tippey764I think driving your car naked will cause the engine to overheatOriginally posted by deevergotesneaky motherfucker
What wrong with your alternator? If the voltage is kicking out weak, maybe replacing the brushes will get it working well again. For that you don't need to remove it.
But I would think remove the cruise control box, then the power steering pump, will give you better access to the alternator.
http://www.youtube.com/watch?v=eYpV7Qkb3X0
there you go!!! hope this helps...i did it in 30 minutes with this videoVS
Mercyboy: I rather lose by a mile because I built my own car then win by an inch because someone else built it for me..your car is your story, so don't let someone else write the book!
MERCYBOY THREAD:http://www.cb7tuner.com/vbb/showthread.php?t=158241
1990 RHD Honda accord si CB3 Canada http://www.cb7tuner.com/vbb/showthread.php?t=196287
MY CB7 ON YOUTUBE: http://www.youtube.com/watch?v=CJID_IxwiNY
