17x10 Rims?
    17x10 Rims?
    is anynone running rims that are 17x10. If so can you please share some pics.
    Thanks.
    That's a tight fit. Alot of stuff factors in. Ride height. Offset. Tire size. Your either gonna have a high amount of poke or a scary stretched tire. 17 x 10 is alottt. But anything is possible to do. Find out what the offset is. And are yu lowered? If so. How much?
      I don't even think a rim that wide will clear the arms without spacers and shit. Then your shit will poke out more than it already would. IDK, might look kind of foolish.
        Unsafe without a lot of money to just waste.
        Good luck.
          I think my rims are 17 x 10 ( gotta check ) my tires are 225/55/17 (rear) 225/45/17 (front) and I have no clearence in the rear, front is okk , but then again the rims may be 17x8
          CB will be out beginning of March
            http://www.cb7tuner.com/vbb/showthread.php?t=103363
            Alek77 ran 9.5" wide wheels in the rear.
            10" is possible if you know what you're doing.
              huh. clearance was the main issue i was seing as well. The rims im looking to buy already come with tires and they don't really look stretched at all.
              The offset on them is 35.
              I always have the option to go with the 17x9's but the 10's just look like monsters.
              ill post pics of them when i get home from work.
                ronald_type-r i think ran 10s
                  I have 17x9 just checked,
                    You're fired.
                      My friend elvis has 17x10 wheels on his cd5. He's lowered not sure how much, with very little camber.
                      Crazy ppl stick rims that wide on a fwd car.
                        Originally posted by HardInThePaint View Post
                        You're fired.
                        I know! I'm getting 16x8 soon because of no clearance
                          He also had fender flares.
                            17x10 is insane and unsafe for any kind of daily use because of camber.
                              bleh i might give up on the idea. i just saw the rims in person and they look like they belong on a Porsche.
                              here is a pic and i was wrong offset is 20.
