tommi : 1990 Accord EX
    UPDATES ON ALL PAGES!!
    Project Name : WingZero (ala cero)
    ::History:: Car has been in my family since 93, I changed hands ownership with my mom in 2003, when she aquired a new car. I started modifying around 03/04 in auto shop class, when i was a soph / junior in HS when I found out about CB7Tuner.com.
    Then after 05 after i graduated the car went under its most extensive work for the first time, heart and auto to 5spd conv. quite an achievement for back in 05 not alot of info was around. and all the OG's were still around.
    NOW
    THEN
    ::PROPULSION::
    2.2i
    Spoon Oil Cap
    Greddy Radiator Cap
    F.P.R. / Gauge
    Diy Oil Catch Can
    Diy E.G.R. Blockoff Plate
    Spoon Reservoir Covers
    Ngk Plug Wires
    C.A.I.
    AEM Bypass Valve
    APEXi Dual Funnel Dry Element Filter (custom made CNC billet flange to mount)
    P.Jdm engine and gearbox magnetic drainplugs
    P.Jdm cf cover
    hood dampers from 92 legend
    :: DRIVETRAIN::
    Auto To 5spd Conversion
    94-95 accord 5spd transmission mount
    LSD Gearbox
    Reverse Lights Wired Up
    06 Civic Si Corsport Aluminum Shifter Bushing Set
    ::HEAT DISSIPATION::
    DC Sports 4-2-1 Header
    Custom Fabbed DP
    RS*R Catback Exhaust System
    Catco High Flow Cat
    ::FOOTWORK::
    Stock "Bottle Caps" 195/55/15 (sold with my coupe)
    Rays Engineering CV Pro Europe 215/45/17 (unequipped)
    Lancer Oz Edition Wheels 215/60/15 (SOLD 9/8/12)
    04-05 TL non Type S wheels with honda centercaps (SOLD 11/4/19)
    SSR Lugnut Taper Conversion Washers
    JDM Schneider A-Tech 17x8 +35 wrapped in hankook concept v2 215/45/17
    ::STANCE::
    NEW Oem Upper Control Arms
    Ingalls Front/Rear Smart Arms Camber Kit
    Progress 22mm rear sway bar
    Function & Form T1 Coilovers For CD5
    ARP Extended Studs
    Annodized Blue Extended Stud Muteki Lugnuts.
    NOW
    THEN
    ::EXTERIOR::
    Oem B54P (Cobalt Blue Pearl)
    92-93 B54P Trunk Lid Swap
    Jdm Door Rain Visors
    New Rear Qtr Panels
    New Pin Stripe
    Edm B54P License Plate Garnish
    Edm G-Square Grill
    Edm 2.2i badge
    CTR (EK9) Sidemarkers
    B54P Power Folding Mirrors
    92-93 Sedan Red/Clear Tailights
    92-93 Jdm B54P Front/Rear Bumper Conversion
    Jdm Si-T Bumper Lights
    jdm 92-93 Fogs
    LEDs In The Brakelights (red)
    LEDs In Corners (amber)
    LEDs In Sidemarkers (amber)
    LEDs In Taglights (white)
    Amber Cornerlights (SOLD)
    Lower Tiebar
    Clear Headlight Covers
    92-93 129A Erebuni Rear Aero Spoiler Fitted To 92-93 Rear Bumper
    Jdm Blackhoused 1 Pc Headlights With Amber Corner Retrofitted With TSX Projectors
    D2R Matsushita oem ballasts
    Relay Harness For Plug And Play 9006>D2R
    6000k D2R bulbs
    Yellow h1 Highbeam With Custom Jumper Harness 9005>h1
    94-95 Oem Accord Front Aero Spoiler
    CB Roof Aero Spoiler (NOT BLIZZSHADE )
    Carbon Fiber CF1 Trunk # 13/13
    Eurolites H3C to H3 Conversion, Ion Yellow Bulbs.
    Jdm Cb4 Fog Mouldings
    Edm Flat Sidemoldings (custom made clips, first one completed on CB7T)
    Carbon Fiber VIS CF Hood with hoodpins (Sold )
    Carbon Fiber Gas lid
    Jdm Luminous light up license plate / holder
    bug deflector(uninstalled)
    HELLA Supertone Horns Behind G-square Grill (First on CB7T)
    BELL License Plate Relocator Custom tabs for jdm plate
    Nostalgic Flair From A Honda S600 In G Square
    6k Colour Led Lights In Reverse Lights
    Rolled Rear Fenders
    ::STICKERS::
    CB7TUNER.COM
    JAF PARKING STICKER
    Hallet Race Circuit Cling
    I <3 MY HONDA Window Cling
    SOCIETY CLOTHING BRAND STICKER
    HONDA OK STICKER
    You like this
    NOW.
    THEN.
    ::RESISTANCE::
    Rear Disc Brake Conversion From A 91 SE
    Nissin Brake Master Cylinder
    EARL'S SS Brakelines.
    Semi Metallic Brake Pads All Corners
    5Lug Conversion Front 95+ RA1 knuckle Oem bearing/Lower Balljoint
    5Lug Conversion Rear 97+ BB6 Non SH Hub Bearings
    ITR ROTORA Slotted Front
    98+ CG1 V6 Rear Rotors
    DA 4040 Proportioning Valve
    BB4 23T Front Calipers / Hardware
    ::INTERIOR::
    Shoulder Pads
    Jdm Oem Fog Switch
    Edm Doorlight Covers (red)
    LEDs In The Doorlights(red)
    White Illumination DC2 Clock
    90-93 DA Tan Cloth Integra Headrests
    96 Spec ITR Steering Wheel non srs
    96 Spec ITR Shift Boot (red stitched)
    Yeamans17 Short Shifter (Bucket Dropped)
    Jdm Spoon Duracon Shift Knob (black)
    Air-spencer Squash Scent
    White LED smd Board In Dome Light
    Jdm Jaf parking sticker in rear window
    91 SE Tan Leather Door Panel Inserts
    Deleted Trunk Springs (cf trunk sits flush now, but feels like a ton)
    3rd Brake light delete shelf
    Manual Seatbelt conversion in Tan
    92-93 Jdm Armrest Tan
    EDM air recirculation switch
    Sparco Speed Bucket(Driver)
    Recaro Slides
    CE1 Recaro Brackets custom made crossbars to fit bucket
    CB9 Storage Tray In Boot
    Corbeau TRS Bucket Seat Narrow (Pass Side)
    Corbeau 4pt Race Harness
    Broadway Mirror 300MM blue tinted and convex
    ::BEATS::
    ::Future plans::
    Flushmount *SOLD*
    Edm Headlight washer nozzles *SOLD*
    Jdm 2pc Headlights SOLD
    Drl Module SOLD
    Jdm CD5 Sports Front Strutbrace SOLD
    Rear Fog Integrated Into Tailight Piece
    Esp Auto-5spd Engine Mounts
    Esp polyurethane Engine mounts
    Edm plates
    Edm Front/Rear Plate Mounts *HAZ*
    u got a lot of work ahead of you keep up the work
    scope out my ride
      nice ride, haha i did a double take when i saw yer tails then figured it out
      ~~~~~~~~~~1991 ExR alb F22a6~~~~~~~~~~
        clean ride i also thought what the hell at first glance on the lights, different but kinda nice
        "Tucking tires and wires."
        The Chronicles.
          I'm not so much a fan of the random stickers on the car, but if you like it, definitely rock em, don't let anyone sway you.
          You say you have a generic strut bar, yet that looks to me like you've got a Neuspeed style one?
          Are those mirrors polarized or is it just the angle?
          Keep up the good work, and nice job on the cancer repair.
            yeah dont love the stickers at all but nice plans
            JDMED
            buy my jdm part
            http://www.cb7tuner.com/vbb/showthread.php?p=544951#post544951
              :werd:
              The message you have entered is too short. Please lengthen your message to at least 10 characters.
              Honda-Tech Username: Lostcb7
              The cb7tuner.com OG.
                love the tails! j/k keep on keepin on
                "Sorry i can't let you in, the back seat is down..."
                  get a new trunk already
                  youre cramping my style!!!!!!!
                  JDMED
                  buy my jdm part
                    yeah i am goin to keep it like that for now or untill i can get the red/clears or the other oem tails, but thx for the contructive criticism.
                      what do you have thats advan?
                      wheres the pic of the spoon oil cap?
                      JDMED
                      buy my jdm part
                        What up man?? nice car. I thought i was the only one who had painted the center cap to my steering wheel. Mine looks lame as shit so if any one has a spare one please hit me up.
                        My Ride
                        myspace
                          i got extras pm me on it
                          and the pics of the spoon oil cap is in progress..
                            well if you guys like it the way it is then i might just leave them the way it is?
                            if not then tell me so i can change them to red/clears that was the reason why i did the trunk swap anyways
                              Trunk Conversion
                              92LX/90EX
