Most Powerful Naturally Aspirated CB7 List
This is a sticky topic.
    Nope, I'm not advocating every joe schmo go dyno his F22A with I/H/E. If you want to make the top of the list, keep building.
    '94 JDM H22A: 178whp 146wtq
      I'd just do top 5 f22's and top 5 or 10 h22's
      MRT: http://www.cb7tuner.com/vbb/showthread.php?t=95154
        Nah....
          Oh well I tried. Its better this way anyways. It'll mean f22 guys will try harder.
            Hey if you went to a different dyno and it read higher does it count?
            Same setup.
            K&N filter
            BLOX 4" velocity stack
            AEM BB6 V2 SRI
            Maxbore 70mm>64mm H23vtec throttle body
            Skunk2 Pro series V2 H22 intake manifold
            OEM RDX 410cc injectors
            AEM adjustable FPR set at 40psi
            PT3 (F22A) cylinder head milled .020" (bumps compression to 9.7:1)
            Bisimoto level 2 regrind
            Bisimoto Pro valve springs
            Bisimoto billet aluminum rocker spacers
            Bisimoto cam gearJDM F23A short block
            Bisimoto V2 4-1 header
            Ktellar 2.5" exhaust piping kit
            Vibrant super quiet resonator
            Xforce varex dual tip muffler
            M2S4 trans
              Sure....
                I still wonder why dynojet dynos are the "industry standard".
                  Hey joey, does that skunk2 throttle body have enough meat to taper it to 74-75mm at the inlet?
                    No clue, probably not. But you're welcome to try....
                      A friends car I did a few weeks ago...
                      H22A
                      Vibrant Header
                      2.5" crushbent exhaust
                      Apexi ws muffler
                      3" short ram
                      Crome gold Pro (Tuned by me)
                      Dynojet Dyno
                      P.S
                      He's also a member here lol
                      Praise The Lowered...
                        still say those are crazy good numbers for a bone stock h22 with bolt-ons, especially with a 2.5" exhaust. must be a euro-R.
                          K&N filter
                          AEM BB6 V2 SRI
                          balance shaft belt removed
                          Bisimoto cam gear
                          NGK blue wires
                          OEM Honda new Cap and Rotor button
                          valve adjustment
                          fully wrapped exhaust
                          M2S4 trans
                          will be testing E85 tune next week sometime.
                          Best:
                          1/4 mile: 13.945@99.98mph
                          0-60: 5.4sec
                            P.S
                            I'm still trying to get right so I can come on down. I have more mods so hopefully I can go beyond that.
                            Originally posted by jdm92_accorn View Post
                            K&N filter
                            AEM BB6 V2 SRI
                            Bisimoto cam gear
                            NGK blue wires
                            valve adjustment
                            M2S4 trans
                            Updated.
                              I added my best et and 0-60
                                K&N filter
                                AEM BB6 V2 SRI
                                Bisimoto cam gear
                                NGK blue wires
                                valve adjustment
                                M2S4 trans
                                Best:
                                0-60: 5.4sec
                                Nice torque curve.
                                Needs MOAR compression. What egt's are you seeing? I've always secretly believed the magic in a bisi header is in the egt's. Curious what you are seeing.
                                Originally posted by wed3k
