Hey guys
after 11months i finish replace my headgasket on 93 accord ><!
I also did h23 im swap
I start it up and it cold idle at 2.5k rpm and all the sudden 3K then 1K then 3K then 2K then 3K
i reinstalled IM again thinking it might be a leak. I also added some hi temp gasket maker to make sure it seal properly
i also made sure FITV is tight down
i found this video with the same symptom i'm having
http://www.youtube.com/watch?v=ClLtJNVE-2M
i get 150 psi on all the cylinder
Could it be my TPS is not properly set?
or Air in the coolant?
my timing belt is not tension properly?
my timing is off?
just need some idea before i troubleshoot it again this weekend
my timing is off?
