ok i have a f22a6 and want 2 know if i could swap the whole h22a1 intake manifold on my f22a6
h22a1 intake manifold swap
Originally posted by bruno8747 View PostThe h22 wont fit but the h23 complete manifold will fit.Stuff 4 sale 2nd gen dsm turbo manifold, ebay type s blowoff valve, 93 ex pt6 ecu, f22a6 camshaft, f22a6 intake manifold, obd1 p13 ecu
The h22's manifold won't bolt up to your f22 block. The h23's manifold WILL bolt up to the f22 block.
If you end up getting an h22 intake manifold, and take it apart, it'll look like this.
Now, the top half of the intake manifold, that I took off.....that's the only part of the h22 intake manifold you can use. You have to keep the lower part of the manifold of your f22a6 that's bolted onto the block. Therefore, if you buy an h22 intake manifold, you can only use the upper half. Might as well buy an h23 manifold if you want to do a complete intake manifold swap.Last edited by Gotz Cb7; 02-22-2009, 10:13 PM.98' Mustang 3V Swap
11' VW CC R36
Originally posted by BB6-SH View PostYou could if you had one of these...http://hondamarketplace.com/showthread.php?t=2015914
98' Mustang 3V Swap
11' VW CC R36
Originally posted by Gotz Cb7 View PostWouldn't that be sort of a restriction? Since the plate's slid over on the left a tad, doesn't it block part of the right off, stopping the air from passing through 100% flowingly?
Go to a junk yard that has both motors, and you shouldn't have any problem
The F22A6 runners are actually better to use then the H23 runners anyway. I hear they are slightly longer. Just take take the IAB plate off the H22 manifold, gut the butterflies and stack it with your F22A6 IAB's. Then take the H22 plenum and put it on top of that. You will also need a H22/23 throttle body because the F series throttle body will not bolt up to the H22/23 plenumLast edited by AbsurdNY; 02-23-2009, 03:39 AM.
yup yup, Absurd. That photo's of an f22a6, complete manifold, but the h22's aren't really different, except for plenum size. But you're right man, if you do end up going through with this, it's best to go all the way. Get yourself a spacer, and make sure you have an h22 throttle body. Thing is, there are some h22 throttle bodies that are smaller than others, meaning...you could actually end up getting an h22 intake manifold, that has a throttle body the same size as the one on the f22a6, which basically wastes time and money. Which is also why it's better to get the h23. With the h23 plenum thrown in an a6 manifold, you won't see CRAZY power, but about 3-4hp maybe. If you were to throw a spacer on there also, they're said to gain 5hp. (blacktrax dyno'd it). Thing is, if you get the whole h23/h22 intake manifold, you automatically have your spacer. Spacer, meaning...the plate your IAB/Butterfly system is in. Instead of explaining, just check this thread out man.
http://www.cb7tuner.com/vbb/showthre...ntake+manifold98' Mustang 3V Swap
11' VW CC R36
Originally posted by AbsurdNY View PostThe F22A6 runners are actually better to use then the H23 runners anyway. I hear they are slightly longer.
