Yesterday, when I just put the key on the ignition, there's a loud beep sound, and the light around the Ignition switch turns on. The driver's door light turns on too and the tiny car on the panel shows the door open as it was. I turned the lights on without start the engine and I heard another warning sound like a bell or something. I know, that's the normal way that those things always should work. Today all those things aren't working again as before. What controls all those functions together? Seems to be a loose cable, damaged plug or something, but where?
Electrical Situation
On the left side of the steering column there is a grey plug. You'll have to remove the column cover and knee bolster to really get to it. However, if the indicator for the headlights on door open is also not working I would check the switch located in the door jam first as that is your most likely culprit.
Its normal for them not to work the bell is the seatbelt warning.
1992 Accord EX Coupe >http://www.cb7tuner.com/vbb/showthre...00#post3060200
Originally posted by keepinitcleanI give it 2 weeks before you sell it.
Originally posted by DarkHusk11 View PostIts normal for them not to work the bell is the seatbelt warning.
Originally posted by PROBLEMATIC View PostIsn't the seatbelt indicator, Im' pretty sure of it. And it's not a fuse either.
Originally posted by coupes View PostI'm pretty sure he's talking about the headlight on indicator and the key in ignition indicator...... that's why I suggested the door pin switch as it would be related to both items not working.
Originally posted by PROBLEMATIC View PostSometimes everything works fine, like 1 time each 3 or 4 months. How can I check or fix it?
